![]() | Home > Technical (L322) > what goes here??? |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7865 ![]() ![]() ![]() |
Nothing, pretty sure it’s for the fuel heater that’s not fitted in the UK…. Slide it out the way.
joninprague Member Since: 29 Dec 2022 Location: surrey Posts: 26 ![]() ![]() |
Thanks so much does sound like it might have been, Just strange to have a fuel filter connected to a pipe that doesn't connect to anywhere?
I’m sure someone with a TD6 they can check will let us know for sure, but I know I had unused cables there.
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1214 ![]() ![]() ![]() |
Mine is exactly the same. As said above, secure it to the side, and forget about it. |
I will do just that |
Dtech Member Since: 29 Nov 2014 Location: Yorkshire Dales Posts: 67 ![]() ![]() ![]() |
I may be wrong, but I think it could be the transmission or front diff breather. In which case it shouldn’t have a cap on the end of it. |
stuart_2006 Member Since: 17 Jul 2018 Location: Holsworthy, Devon Posts: 126 ![]() ![]() ![]() |
The little filter is an air vent for turbo actuator vacuum system. Shouldn't have anything on the end of it. |
Thanks for that so should i just remover the fuel filter looking thing so the pipe has nothing on the end and then just tuck them away?
Nope, the filter should be there on the end of the pipe to stop small animals being sucked in. But looking at your photo it looks like the top connection on the filter has a bit of black pipe on it and may be blocked off? Shouldn't be anything on the top connection of the filter. |
Perfect I will take the pipe off the top.
