![]() | Home > Technical (L322) > Battery flat and Emergency key won’t unlock the door |
V8 Bob Member Since: 15 Mar 2018 Location: Cumbria Posts: 374 ![]() ![]() ![]() |
Do you have a tow bar fitted? Can usually connect a charger via the electrics that should let you in. Alternatively need to access starter motor and connect via the main electric feed to the solenoid. 2012 tdv8 Westminster arrived Jan 19 gone Dec 23
Grundey2 Member Since: 03 Jan 2023 Location: Lincolnshire Posts: 31 ![]() ![]() ![]() |
I don’t have any tow at electrics.
oggy Member Since: 09 Sep 2020 Location: padstow cornwall Posts: 395 ![]() ![]() ![]() |
have you tried putting power through the side wing repeater new vehicle purchase
No, do I just pop the indicator out and connect live to one and neutral to the other?
the way i should do it is to pop the repeater out and expose both wires connect the earth wire from the doner battery to a good earth on the vehicle that leaves the positive live to deal with touching one of the bare wires with the live from doner battery . have your remote handy to press new vehicle purchase
Thanks for the advice. Does it matter which wire I connect the live too? Will I do any damage if I get the wrong one?
On a 4.4 tdv8 the starter is accessed from behind the drivers
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16336 ![]() ![]() ![]() |
Uhhhh YEAH don't get the + & - the wrong way around for christ's sake... ![]() Side repeater will have an obvious - wire which will be black... ![]() |
p38arover Member Since: 16 Dec 2015 Location: Western Sydney Posts: 1558 ![]() ![]() |
The OP Mentioned the emergency key. Doesn’t the 2010 MY have a conventional key to use in the lock? Ron B. VK2OTC
just read the post stating that the black is - neg new vehicle purchase
I tried the repeater but it didn’t work.
okay James bit more work is involved this way but get to the alternate and energize the battery from their new vehicle purchase
Am I right in thinking it’s OS wheel off, liner out and keep going till you find either the starter or Alternator? |
what is the engine model James if you are going in the wheel side and liner out the bonnet cable runs behind the liner on o/s I have seen a vid showing someone giving the outer cable a good pull and the bonnet opened . if not might need to remove the engine cover and get underneath to get at the alternator
