Home > Maintenance & Mods (L405) > Battery
broncoupe
Battery
Have 2017 L405 need a reasonable tool to reset car after battery change suggestions please
Post #655714 5th Feb 2023 7:44pm
jumpin mouse
United Kingdom 2015 Range Rover Autobiography SDV8 Aruba
My 2015 had a new battery fitted recently and no reset was required.
Post #655727 5th Feb 2023 8:54pm
broncoupe
unfortunately mines coming up with low battery warning
Post #655734 5th Feb 2023 9:24pm
Gremlin500
For a reasonable price, the iCarSoft LR V3 about £150 when on offer, will do 90% of the functionality of the iiD BT (£440).
I have found it very intuitive and easy to use, with free lifetime upgrades available over the internet. Thumbs Up “If it ain’t broke, don’t fix it” -where’s the fun in that?
Post #655754 5th Feb 2023 11:14pm
broncoupe
Thanks thats really useful I found that unit online earlier have emailed the seller Thumbs Up
Post #655761 5th Feb 2023 11:50pm
MrWold
England 2014 Range Rover Autobiography SDV8 Barolo Black
Bought mine direct from https://www.ukpartsdirect.com/
There is also the LR V2 which has slightly less functionality and the CR versions which do 10 different makes Chris
2014 FFRR 4.4 SDV8 Autobiography Barolo Black
2012 RRS SDV6 HSE Baltic Blue
and before I saw the light:
2011 Suzuki Grand Vitara SZ5
1998 Ford Mondeo V6 Ghia X
1990 Citroen BX GTi
1973 Triumph GT6
Post #655778 6th Feb 2023 9:49am
broncoupe
Trying to find out if V3 version is improvement do you know the difference
Post #655782 6th Feb 2023 10:17am
MrWold
https://www.icarsoft.com/Article/s-126-126.html Chris
1990 Citroen BX GTi
1973 Triumph GT6
Post #655785 6th Feb 2023 10:26am
broncoupe
Thanks for info bought V3 version really helpful people Thumbs Up
Post #655786 6th Feb 2023 10:35am
caymanblack
Never having used one of these how does it work?
So you have fitted a new Battery what do you do plug this in somewhere then what?
What else would you need it for, I see it says service reset, so you can by pass the manual way with just plugging this in?
Sorry if these are stupid questions just want to know if they are worthwhile. thx.
To answer my own question.
 overfinch modified
Post #655793 6th Feb 2023 11:05am
mlambton
United Kingdom 2015 Range Rover Autobiography SDV8 Corris Grey
My MY2015 battery has come up low a couple of times this winter mainly because i have short trips and heated seats/steering wheel heater on too. What is the going rate for a decent replacement main battery? 2015 Range Rover L405 SDV8 AB Corris grey
2010 Range Rover TDV6 HSE Narra Bronze sold
2006 Discovery 3 SE green sold
Defender 90 td5 sold
Defender 90 soft top sold
Post #655839 6th Feb 2023 6:58pm
Gremlin500
@Caymanblack:
Check this out:
IIRC, main difference V2 vs V3 is suspension calibration amongst lesser things.
It’s menu-driven and very intuitive IME.
Post #655842 6th Feb 2023 7:03pm
caymanblack
Thanks Gremlin. Thumbs Up overfinch modified
Post #655892 7th Feb 2023 10:39am
cass
Try Tayna.co.uk
IMO you are better off changing it sooner rather than later. Many people seem reluctant to change a battery until it causes a breakdown yet the cost is a drop in the ocean of RR running costs.
Post #655897 7th Feb 2023 11:15am
broncoupe
Theres OBD connector under dash drivers side just plug it in it will power up and follow on screen prompts
units can cause dash to light up like Christmas tree don't panic the unit can interrupt message flow of car once your finished
cycle ignition and everything will be ok
Post #656086 9th Feb 2023 10:11am
