Home > Maintenance & Mods (L405) > L405 Oil Cooler Coolant Leak
Tuckmeister
United Kingdom 2013 Range Rover Vogue SE SDV8 Causeway Grey
Hi Guys do any of you have any experience, with Oil Cooler Coolant Leak ?
Is it a new gasket kit or Oil cooler as well ? & what sort of Price / labour costs involved, just had car serviced & advisory in notes was coolant leak on oil cooler.. Would have thought the garage would have contacted me & advised whilst servicing car ? but got the feeling they did not want to get involved !!!
Does it mean dropping oil out etc,
2013 4.4v8 L405 Range Rover P38
Range Rover L322 Vogue
Range Rover Sport 4.2 SC
Range Rover l322 5.0 V8
Range Rover L405 TDV8 4.4
Post #655693 5th Feb 2023 4:29pm
JayGee
Oil leaking from the oil cooler is a common issue on these engines - almost inevitable and plenty of info on it if you use the search engine Wink . If it's leaking coolant it may be the EGR cooler below it - pray it isn't as it's a much more expensive and complicated job. 2012 TDV8 Vogue (L322)
Post #655712 5th Feb 2023 6:34pm
Tuckmeister
Hi JayGee
I have been told the oil cooler is leaking coolant ie Antifreeze not oil as my header tank was low.. Question Question Question Range Rover P38
Post #655852 6th Feb 2023 6:42pm
JayGee
It may be the EGR cooler under the oil cooler then - unfortunately this is a much more difficult job. 2012 TDV8 Vogue (L322)
Post #656328 12th Feb 2023 10:12am
Tuckmeister
what sort of costs involved ?? Labour i presume most expensive.. How big off a job ??
Thanks for information Range Rover P38
Post #656356 12th Feb 2023 4:51pm
JayGee
Get a proper diagnosis before you go any further. A garage with a borescope should be able to see where the coolant is coming from. I also suggest a specialist LR garage rather than a general garage. 2012 TDV8 Vogue (L322)
Post #656432 13th Feb 2023 9:04am
Huwrhys
United Kingdom 2017 Range Rover Autobiography SDV8 Loire Blue
I had the same diagnosis from a main dealer but it turned out to be the thermostat housing. It’s a three hour job once they have the parts. Housing is £125ish and labour approximately £400.
Good luck. Thumbs Up
Post #658596 6th Mar 2023 7:45am
Marcel M6
United Kingdom 2012 Range Rover Westminster TDV8 Buckingham Blue
'Once they have the parts' seems to be an issue at the monet. have same problem on mine. I've been told upper and lower thermostat housings/pipes etc are out of stock until May!
Oil coolers also in short supply but did at least manage to find one of those.
Post #658637 6th Mar 2023 1:30pm
