Home > Technical (L405) > Engine oil change anomaly - insufficient oil
baz000000
England 2016 Range Rover Autobiography SDV8 Loire Blue
I did a oil suction change on my SDV8 today and hit a problem refilling the engine, the level indicator said insufficient oil so I added more, and more and gave up at 9l with the screen still showing insufficient oil. The spec is 9.4l and I did not measure what came our. I did the service indicator reset using an OBD tool and then the oil level was not available.
I tried dipping the suction tube with 1mm wire but that didn't get down the tube more than 10cm before hitting an obstacle. A OBD scan showed no errors so I took the car for a gentle drive, to the local pub. Came out after 1 pint and the oil level indicator was restored, reading just under full.
It would be so much easier if there were a dipstick.
Post #655600 4th Feb 2023 7:16pm
dingg1
Yep, Censored stupid idea from the designers Banging Head
Post #655625 4th Feb 2023 10:19pm
dingg1
In fact I'd go further and say who's idea it was should never be allowed to work in vehicle design again and whoever signed it off as a good idea, should be kicked in the balls by whoever has an issue with it.... 👍
Post #655626 4th Feb 2023 10:22pm
Phoenix
The 'idea' came from focus groups of previous model owners who basically wanted to have an oil level warning or method of checking it without having to dirty their hands....
Blame them, not the ones that implemented their stupidity & laziness.
Post #655627 4th Feb 2023 10:27pm
fisha
The procedure is clear about getting it up to temp and then leaving it to settle along with other steps to take for it to properly assess the oil level in the vehicle … I think it reads a short term level and a long term level.
Personally, having changed the SDV8 oil for the first time recently and using the suction method, I cant believe it’s not been a standard way of doing it across all cars. The process was so much easier, cleaner and hassle free.
( I do agree that there should also be an actual dipstick on them too. ) V8 or else ...
Post #655631 4th Feb 2023 10:45pm
Gremlin500
I recall when I first acquired my MY 2017 L405 a year ago, oil level was totally unavailable, no matter what I tried.
Following a visit to my local LR indy, many fault codes were cleared and the oil level sensor was plugged back in after being left unplugged for some reason during a recent “service” by the selling dealer. I later obtained a copy of the service sheet, to see various items including an oil filter, but no OIL itemised on the bill! Shocked
I immediately instructed them to service the car again properly at a cost of £600, fortunately still within the required JLR period. Censored Censored Censored “If it ain’t broke, don’t fix it” -where’s the fun in that?
Post #655634 4th Feb 2023 11:02pm
dingg1
Instrumentation breaks down, a dip stick never does, the problem lies with the designers NOT potential/owners requests... 🙄
Post #655638 4th Feb 2023 11:30pm
Its important to first check the digital level... Then empty the oil, measuring the amount you remove... Before refilling using the same amount or more engine oil, if required? Thumbs Up
Post #655639 5th Feb 2023 12:29am
Phoenix
Well, you say that... when I worked at an Audi dealer, there was a 'high oil consumption' job in (one of many...) we ran all the checks and it was OK but the guy kept coming back saying he'd had to top up 0.5 litres within a day of us doing the checks. Turned out he'd retrofitted his own dipstick as he didn't trust the level sensor - with one that was too short.
Post #655652 5th Feb 2023 9:48am
Phoenix
We never did that, always just drain & fill to measured quantity, the level should be an indicated 3/4 full at cold, you can get the level on screen by repeatedly pressing the cruise control 'cancel' on the steering wheel if it shows as unavailable.
Post #655654 5th Feb 2023 9:52am
dingg1
Phoenix, there's no accounting for the 'dipstick' using the dip stick 😂😂😂
Post #655655 5th Feb 2023 10:13am
baz000000
I've never read that you can hit the cruise a few times to restore the oil level readout, is that a manual specified method or did someone just hit on it while beating the car up out of frustration?
Post #655657 5th Feb 2023 10:16am
IIRC you need the bonnet open to do the cruise cancel trick.... Thumbs Up Pete
Post #655658 5th Feb 2023 10:17am
Kot
Simply pull the bonnet release, get in and press the start buttton (without your foot on the brake).
Press "OK" to clear any warnings ( including'bonnet open' )- once they are clear, do the oil check as normal but when it comes up "unavailable" press 'cancel' on the cruise control twice - your oil level shows! 2018 SE SDV8 4.4 Byron Blue
Post #655662 5th Feb 2023 10:59am
Phoenix
Yep, I forgot that bit - but we had the bonnet open anyway! IIRC it was something LR retrospectively put in the software for workshop level checks after 'dealership feedback', it's important to remember that it should only be filled to ~3/4 using a cold level check though.
Post #655671 5th Feb 2023 1:13pm
