Home > Technical (L405) > Engine oil change anomaly - insufficient oil |
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1348 |
Yep, stupid idea from the designers |
4th Feb 2023 9:19pm |
4th Feb 2023 9:22pm |
Phoenix Member Since: 16 May 2022 Location: Gone Posts: 1631 |
The 'idea' came from focus groups of previous model owners who basically wanted to have an oil level warning or method of checking it without having to dirty their hands....
4th Feb 2023 9:27pm |
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1391 |
The procedure is clear about getting it up to temp and then leaving it to settle along with other steps to take for it to properly assess the oil level in the vehicle … I think it reads a short term level and a long term level.
4th Feb 2023 9:45pm |
Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1525 |
I recall when I first acquired my MY 2017 L405 a year ago, oil level was totally unavailable, no matter what I tried.
4th Feb 2023 10:02pm |
Instrumentation breaks down, a dip stick never does, the problem lies with the designers NOT potential/owners requests... 🙄 |
4th Feb 2023 10:30pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16302 |
Its important to first check the digital level... Then empty the oil, measuring the amount you remove... Before refilling using the same amount or more engine oil, if required? |
4th Feb 2023 11:29pm |
Well, you say that... when I worked at an Audi dealer, there was a 'high oil consumption' job in (one of many...) we ran all the checks and it was OK but the guy kept coming back saying he'd had to top up 0.5 litres within a day of us doing the checks. Turned out he'd retrofitted his own dipstick as he didn't trust the level sensor - with one that was too short. |
5th Feb 2023 8:48am |
We never did that, always just drain & fill to measured quantity, the level should be an indicated 3/4 full at cold, you can get the level on screen by repeatedly pressing the cruise control 'cancel' on the steering wheel if it shows as unavailable. |
5th Feb 2023 8:52am |
Phoenix, there's no accounting for the 'dipstick' using the dip stick 😂😂😂 |
5th Feb 2023 9:13am |
baz000000 Member Since: 01 Apr 2022 Location: Shropshire Posts: 138 |
I've never read that you can hit the cruise a few times to restore the oil level readout, is that a manual specified method or did someone just hit on it while beating the car up out of frustration? |
5th Feb 2023 9:16am |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8311 |
IIRC you need the bonnet open to do the cruise cancel trick.... Pete
5th Feb 2023 9:17am |
Kot Member Since: 10 Mar 2021 Location: broadland Posts: 1246 |
Simply pull the bonnet release, get in and press the start buttton (without your foot on the brake).
5th Feb 2023 9:59am |
Yep, I forgot that bit - but we had the bonnet open anyway! IIRC it was something LR retrospectively put in the software for workshop level checks after 'dealership feedback', it's important to remember that it should only be filled to ~3/4 using a cold level check though. |
5th Feb 2023 12:13pm |
