Home > Technical (L322) > Help guys l322 4.4 tdv8 poorly
rangemad
United Kingdom 2006 Range Rover Vogue Td6 Java Black
Hi everyone
Love some advice
About week a go i had red dpf full visit dealer…then went into limp mode
So i called a mobile dpf guy to sort it
When he arrived first thing he did was plug in
This what came up
P2463-00 permanent-Dpf restriction soot accumulation bank 1
P040D-00 permanent-EGR temperature sensor A circuit high
He then said it wont let me regen the Dpf cos of the Egr fault
So of he went
Yesterday nipped to local garage he had advised to delete the
Dpf and delete the Egr for a price of £700
What you guys think
Post #655561 4th Feb 2023 10:03am
JayGee
Just replace the EGR temp sensor? 2012 TDV8 Vogue (L322)
Post #655570 4th Feb 2023 11:38am
Baltic Blue
My old Independent garage was always adamant that the PO 40 D EGR fault prevents DPF forced regens, but I can assure you that it Doesn’t.
Mine has has the EGR PO 40 D alarm showing ever since I bought my Gap iid at least 6 years ago and I have performed several Forced regenerations ever since the facility was added.
Just this week I have forced it to reduce the soot level from 18 .6 to 2.74g.
Post #655571 4th Feb 2023 12:10pm
misfire84
United Kingdom 2012 Range Rover Vogue SE TDV8 Santorini Black
yes it only takes a hour or so , and saves all the potential mot probs ets 2012 Black 4.4 TDV8
1968 Mgb Gt
Post #655572 4th Feb 2023 12:23pm
JayGee
Mike.
Why did you need to do a forced regen at 18.6g? 2012 TDV8 Vogue (L322)
Post #655574 4th Feb 2023 1:04pm
Baltic Blue
Because I am a sad old man who doesn’t get out much in winter Rolling with laughter
My last months usage has not seen a single journey long enough to initiate a natural Active regen , but several passive regens have kept it just below the 19.2g trigger level .
Post #655575 4th Feb 2023 1:20pm
