Home > Maintenance & Mods (L322) > Hidden LED bar |
Phoenix Member Since: 16 May 2022 Location: Gone Posts: 1631 |
There isn't a lot of room, you'd also need one of the curved ones to maximise the space.
3rd Feb 2023 9:52pm |
Faukstad Member Since: 27 Dec 2021 Location: Oppland Posts: 63 |
Nice!
3rd Feb 2023 9:55pm |
I'll take one tomorrow - I made the mounts from Aluminium registration plates, the 3mm stock sheet I had was too thick to fold properly, the bottom is drilled to take the bumper fixing screws, at the top, I drilled out a blind rivet on the crossmember / slam panel and made the length between folds ~3mm short so the mounting plate would be pulled tight between the fixings.
3rd Feb 2023 10:39pm |
Cheers buddy, appreciate it. |
3rd Feb 2023 10:42pm |
ikjos Member Since: 09 Sep 2019 Location: Hornindal Posts: 41 |
I gave up the idea about hiding the LED-bar, went fully visible instead
4th Feb 2023 9:54am |
wayneg Member Since: 05 Jun 2013 Location: South Fremantle, Australia ( ex London ) Posts: 785 |
Not convinced hiding auxiliary lighting is a good idea. If you need extra lights get them up and unobstructed. On my previous TD6 I made up custom brackets for a light bar at the top of the grill. I still have the bar but would fit with a numberplate bracket if I decide to fit it.
4th Feb 2023 11:31am |
If it were more than just 'fill in' whilst the HiD's got up to full output, I'd agree. I accept there will be some losses & diffusion and I wouldn't suggest it has a function other than short range flood lighting.
4th Feb 2023 3:40pm |
Tidy job there Phoenix.
4th Feb 2023 9:17pm |
Thanks, it's not bad - I knocked up one side between paying jobs on a Saturday, the measurement and trial fits took the time, the other side is just a mirror so you don't need to re-measure everything.
4th Feb 2023 9:36pm |
If you look at the photo of my old TD6 you will see the main light bar but also there are two lower down on the bumper the same as Phoenix`s lights. The lower ones were switched separately and angled outward slightly outward, used as trail lights. the main bar was wired with a remote control relay so could be switched from inside or outside of the car. The light output was massive
5th Feb 2023 12:34am |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16230 |
Ive sold tonnes of these to van owners who lease their vans... That way they can fit & remove them without any long term damage... Fitted lots to D4's but not to a FF as yet... |
5th Feb 2023 12:40am |
