Home > Technical (L322) > Loose Headlamp - MoT failure
paul70
Sorry folks but after advice, MoT failed today because of OSF healamp insecure. Hadn't noticed at all as it sits perfectly flush but if you grip the side and pull it, it is really loose. I have taken a quick loook and the bracket on the top has a crack which allows the top to have a little movement but would be simple to fix with an additional bracket or GRP/Resin repair. The question is what secures the bottom as I can't see as it's below the bumper??
I hope it doesn't mean a complete bumper removal job!
Many Thanks in anticipation.
Paul
Post #655398 1st Feb 2023 7:14pm
oggy
United Kingdom 2007 Range Rover Vogue SE 4.2 SC V8 Java Black
hi paul no bumper removal. remove the grill 3 bolts on the top lift it away and disconnect the temp gauge from the back of the grill. and you will see a 10 mm bolt in the bottom corner grill side and the 2 blots on the top it will side out. put a hand towel on top of the bumper to rest it on so you don't scratch the top of the bumper for when you disconnect the multi pin connector .before you put it back in clean up the multi-pin connector with some switch spray so it will slide in better until it clicks job done new vehicle purchase
2007 supercharged 4.2 java black .sand leather vogue se trim
previous cars .
range rover classic 200 tdi
discovery 1 200 tdi
freelander 2 2008 hse
discovery 1 300 tdi
p38 4.0 ltr man r380 ex royal support vehicle on v5c
discovery td5 man off roader
Post #655404 1st Feb 2023 7:53pm
paul70
Thanks I’ll give it a go tomorrow Thumbs Up
Post #655410 1st Feb 2023 9:20pm
paul70
Thanks agin. I found the bottom mounting broken but think it will fix. Time will tell as glued with UHU max power repair and will take 24hrs to fully harden. Top bracket also glued again but I may make some sort of extra bracket for strength on refitting being that it had been repaired before. Hope I can salvage it as the headlights are so expensive on the 2010-12, cheapest on ebay currently £450!! Seen new ones listed at £1200+vat can't seem to find any type of repair kit as you do with some manufacurers headlights.
Post #655439 2nd Feb 2023 5:33pm
