Home > Maintenance & Mods (L322) > Deployable side step jammed
Squirrel
United Kingdom 2009 Range Rover Autobiography 5.0 SC V8 Galway Green
My offside deployable side step is jammed open. Do I need to dismantle everything to try and free it, or is it more likely the motor is faulty?
Some history: the side step spent a little bit of time jammed in the "mostly closed" position, but now it's jammed fully open. I can hear the motor attempting to shift it and it does wobble a bit when it thinks it should retract, but it doesn't move.
Any and all ideas gratefully received! There's a fair bit of info on side steps on here, but it's taking me some time to wade through it all so I thought I'd ask.
Post #655254 31st Jan 2023 2:48pm
DrRob
You could just bin them if causing issues? They fail and rot out with superb reliability Laughing Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #655258 31st Jan 2023 3:11pm
comports
United Kingdom 2016 Range Rover Autobiography SDV8 Mariana Black
If you can hear the motor trying then there is 'some' life in it - Others I have read suggest copious amouints of wd40 on the motor/pins and leave to soak for quite a while (then do it again) and manually 'help it' to retract when you close the door.
If you get it working again, apply plenty of grease on the moving parts.
ITs hit n miss if its already sticking but you don't have much to lose at this point Ash
2022 SDV8 AB
2016 TDV8 VSE
2011 TDV8 VSE
2006 V8 Vogue
2002 2.5 Vogue
Post #655259 31st Jan 2023 3:18pm
Squirrel
Yes, the motor is doing its best to retract the step, but it's not for budging!
Being vertically challenged, I quite like the side steps - and I prefer the deployable type to the fixed ones. I gather Land Rover no longer make them. Am I setting myself up for lots of expense if I want to replace one or both? Is it even possible?
Thanks for all the help! Thumbs Up
Post #655262 31st Jan 2023 3:55pm
Squirrel
If anyone’s interested - I managed to fix the jammed step. I cleaned the general filth off it, gave it a wipe down and then applied loads of PTFE lubricant. That made it move a bit, so I’ve been giving it a bit of a shove every morning and topping up the PTFE. It looks as though the pins were seized.
Post #655684 5th Feb 2023 3:01pm
