![]() | Home > Maintenance & Mods (L322) > Deployable side step jammed |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4334 ![]() ![]() ![]() |
You could just bin them if causing issues? They fail and rot out with superb reliability |
comports Member Since: 20 Dec 2010 Location: Colchester Posts: 1754 ![]() ![]() ![]() |
If you can hear the motor trying then there is 'some' life in it - Others I have read suggest copious amouints of wd40 on the motor/pins and leave to soak for quite a while (then do it again) and manually 'help it' to retract when you close the door.
Squirrel Member Since: 15 May 2012 Location: Reading Posts: 212 ![]() ![]() ![]() |
Yes, the motor is doing its best to retract the step, but it's not for budging!
If anyone’s interested - I managed to fix the jammed step. I cleaned the general filth off it, gave it a wipe down and then applied loads of PTFE lubricant. That made it move a bit, so I’ve been giving it a bit of a shove every morning and topping up the PTFE. It looks as though the pins were seized. |
