Home > Maintenance & Mods (L322) > 05 L322 Vogue won't start
Brakster
Australia 2006 Range Rover Vogue Td6 Stornoway Grey
I know a lot will say get a code reader but I don't have one here are my symptoms
1 Turn key to Position 2 all lights on dash light up
2 Turn key to start a low pitched morse code type sound comes from behind dash ,I have replaced battery with a know good one no difference .Tried tapping starter motor with hammer no difference
checked voltages on fuses 18,25,31 ,39 and all correct as key is turned to start position
when fault first occurred on only one occasion I was able to start vehicle when I actuated and deactivated central locking but now will not start
OK I CAN CLOSE THIS THREAD DOWN IT TURNED OUT TO BE THE IGNITION SWITCH ,I PUMPED A FEW SQUIRTS OF CRC INTO IT AND IT NOW WORKS AND STARTS EVERY KICK ,THANKS YOU FOR ALL THAT HELPED ME ,IF FAULT RE APPAERS I WILL CHANGE IT
Post #655107 30th Jan 2023 4:10am
Merchy
Not 100% sure but read the below thread, you may have the same fault.
https://www.fullfatrr.com/forum/topic65846.html
Post #655112 30th Jan 2023 10:08am
littlecub
Australia 2003 Range Rover HSE Td6 Epsom Green
Hi Brakster,
Give Justin a call on 62291102 or 0408995635.
He's in Kingston.
He is the guru you call when in Tassie
cheers
littlecub
Post #655188 30th Jan 2023 8:55pm
Brakster
yes i have talked to Justin but vehicle is not drivable might have to get it towed to him I thought if I could locate start relay i could get it running to take to him
Post #655222 31st Jan 2023 8:58am
Brakster
Does any on know on an 05 L322 Vogue where then start relay is located on all the forums it states it is behind the ECU cover behind the battery but its not there , I think that only applies to V8 models and not TD6 so at this stage i am still searching for this relay to try and bridge it out ,I also disconnected the battery last night and after I reconnected it the car started but as soon as I turned the ignition to off position and tried to restart it was back to original fault , i am starting to suspect immobiliser , i can buy a used unit on eBay ex uk but i guess i will need to program my keys to new immobiliser is that still a simple process.
Post #655223 31st Jan 2023 9:00am
Merchy
Found this for relays and fuses
https://www.google.com/url?esrc=s&q=&a...AEKGuEycWz
Post #655234 31st Jan 2023 10:51am
