Home > Maintenance & Mods (L322) > 05 L322 Vogue won't start |
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1210 |
Not 100% sure but read the below thread, you may have the same fault.
30th Jan 2023 9:08am |
littlecub Member Since: 02 Apr 2013 Location: Ulverstone,Tassie Posts: 325 |
Hi Brakster,
30th Jan 2023 7:55pm |
Brakster Member Since: 08 Oct 2019 Location: TASMANIA Posts: 5 |
yes i have talked to Justin but vehicle is not drivable might have to get it towed to him I thought if I could locate start relay i could get it running to take to him |
31st Jan 2023 7:58am |
Does any on know on an 05 L322 Vogue where then start relay is located on all the forums it states it is behind the ECU cover behind the battery but its not there , I think that only applies to V8 models and not TD6 so at this stage i am still searching for this relay to try and bridge it out ,I also disconnected the battery last night and after I reconnected it the car started but as soon as I turned the ignition to off position and tried to restart it was back to original fault , i am starting to suspect immobiliser , i can buy a used unit on eBay ex uk but i guess i will need to program my keys to new immobiliser is that still a simple process. |
31st Jan 2023 8:00am |
Found this for relays and fuses
31st Jan 2023 9:51am |
