![]() | Home > Technical (L322) > 4.2 v8 supercharged metal lumps in oil |
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1214 ![]() ![]() ![]() |
Although possibly pointless, did you take a pic of the 5 pence sized piece? Whilst it is still running OK for now, it sounds like very bad news, as a marine engineer finding that would give me the heebie jeebies. All depends upon the overall condition of the vehicle. The least I would want to do is drop the sump pan to have a good look, I don't know how difficult / easy it is on yours. Or drop the oil in another few hundred miles and see it there are more bits.
Jmiller Member Since: 20 Jan 2023 Location: Wiltshire Posts: 6 ![]() ![]() ![]() |
No didn’t take pictures, I couldn’t possibly sale it knowing what I’ve found wouldn’t be fair.
Does sound like the block, just keep your fingers crossed and do the oil change again later. Know what you mean about selling, I could not do that either. |
Yeah will do another change in a few weeks if it’s still alive ! And report back |
oggy Member Since: 09 Sep 2020 Location: padstow cornwall Posts: 395 ![]() ![]() ![]() |
just a thought could the timing chains and tensioners have been changed and it is parts of the tensioners or pieces of the tensioners that have gone in the sump pan? my first move would be to drop the sump and see if any bits are left just for peace of mind and any history of this being done on the paperwork. or a way to look at it do the chains and tensioners need doing? new vehicle purchase
Good thought oggy ! What ever has failed it’s not effecting the car at the moment engine sounds and runs sweet ! Hopefully tensioner and previous repair never cleared it all out .
it is easy to say to someone drop the sump but it is not looking a very easy job probably the reason why it was left and not removed. when you drop the oil again try and get a magnet through the sump drain plug and see if you can pick up any more from the bottom of the sump pan .or see if anyone has an endoscope camera you could borrow to have a look new vehicle purchase
Just found you can get a magnetic sump plug , will purchase one drop the oil again this week see what’s in there then put the magnetic one in for a month then drop oil again , unless it goes bang or develops a knock or rattle |
that is sounding a good idea. you could always flush the sump pan out if you put a tube over the dipstick tube with a couple of jubilee clips with a good flow of red diesel to flush it out or put say 6 litrs in the sump and then undo the plug see what comes out . new vehicle purchase
Quick update, dropped oil again 2 weeks ago only a few minor flecks of metal came out , I’ve done nearly 1000 miles since then with no problems! I’m starting to think it was the tensioner that broke up and the mechanic who changed it was very lazy and didn’t clean up properly or maybe didn’t realise few bit had made it into the sump ! Will drop oil again in 2 weeks but think it may of dodge a bullet there |
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2272 ![]() ![]() ![]() |
well thats encouraging good luck |
that is sounding okay did you change the filter same time new vehicle purchase
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3149 ![]() ![]() ![]() |
If the lumps of metal in the sump were important it’d not be running as well as it is IMO.
Interesting info above, I was not aware that those parts were cast, that is encouraging news |
