Home > Technical (L322) > Immobiliser issue or something else? Morse code noise |
J90 Member Since: 02 Jul 2013 Location: Somewhere south of Bergerac Posts: 651 |
https://youtube.com/shorts/LB-UUzhkBxM?feature=share
27th Jan 2023 4:52pm |
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1181 |
Same happened to me (2006 Td6), key in, turned ok, transponder recognised etc, steering wheel lowered into position, EVERYTHING worked but engine would not start, not even attempt to turn over, noise with mine sounded a 'little' different, but other wise had the same situation. No warning lights at all.
27th Jan 2023 6:26pm |
Just a quick addition to what I said - when mine failed, at first it was the odd random start failure, which became more frequent, then it failed completely whilst on my driveway, I was lucky that day
27th Jan 2023 7:10pm |
Merchy, did you have to buy new keys as well? Is the replacement ignition switch a separate part or is it part of a whole new ignition barrel as well?
27th Jan 2023 7:14pm |
Merchy, it's +3๐, but it's the french back of beyond for anything Rangie related. The 4x4 of choice here is the Dacia Duster, so out of pure pride I have to get my old ๐ฌ๐งL322 back on the road๐ Travelling around in circles again. |
27th Jan 2023 7:30pm |
No new keys needed Once you disconnect the wiring harness as in the guide, you remove the assembly and then split the steel barrel etc from the plastic ignition switch, (completely separate part) fit new switch and bingo.
27th Jan 2023 8:25pm |
Thanks for the extra info๐ Travelling around in circles again. |
27th Jan 2023 8:38pm |
Brakster Member Since: 08 Oct 2019 Location: TASMANIA Posts: 5 |
I had exactly the same symptoms and was going down the immobiliser path ,it turned out to be the ignition switch ,i have not fitted a new one yet i just squirted CRC into it and turned it on and off quickly and it has started perfectly since then |
1st Feb 2023 8:46am |
Thanks for the tip๐๐ Travelling around in circles again. |
1st Feb 2023 10:29am |
