![]() | Home > Maintenance & Mods (L322) > Waxoil. |
My tip would be avoid waxoil. Have a look at Lanoguard. 2012 TDV8 Vogue (L322) |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8514 ![]() ![]() ![]() |
I'll second don't use waxoil, they were the market leader 30+ years ago but have not updated anything since...
KitTheRam Member Since: 29 Mar 2022 Location: Essex/Herts Border (originally from Derby) Posts: 445 ![]() ![]() ![]() |
Thanks. Ideally looking for someone to do it and it to last longer than a year unless that’s unrealistic! 2009 pre-facelift 3.6 TDV8. |
JCW Member Since: 13 Apr 2013 Location: Cotswolds Posts: 901 ![]() ![]() ![]() |
Although relating to Defenders, this thread provides loads of general advice 👍
A1GSS Member Since: 24 Dec 2010 Location: Saffron Walden, Essex Posts: 1973 ![]() ![]() |
If you can wait a couple of months for the update I’ll let you know how it goes. Zagato is doing my 2010 RRS in March. Graham
Thanks. Yes please update this thread if you can.
Will do. Had a long chat with him about the car and everything that needs doing. Seems to be very knowledgeable about what works and what doesn’t.
TJH1985 Member Since: 11 Feb 2015 Location: Nottingham Posts: 664 ![]() ![]() ![]() |
As a former defender owner, I had success with Dintrol but only if I used something to kill/stabilise the corrosion first and if required use mechanical removal followed by something like the buzzweld products to paint prior to coating.
Ramblin Man Member Since: 05 Apr 2022 Location: Southsea Posts: 289 ![]() ![]() ![]() |
I had mine fully treated with Dinitrol underneath by https://www.southwestrustproofing.co.uk/
Proftinkerpot Member Since: 23 Dec 2022 Location: County Antrim Posts: 193 ![]() ![]() ![]() |
TJH, I was speaking to a local firm called Chassis Seal NI. He specialises in doing Landrover Defender chassis' prior to restorations. He has been using Dinitrol for many years and apparently the new Dinitrol product has a rust inhibitor / convertor built in, making it a single stage application. The process involves pressure injection spraying inside the chassis box sections, then plastic arch liners removed, brake pipes and flexible masked to enable underside to be sprayed. Process takes 2-3 days and I was quoted £850. He said it is a one off application and he would never expect to need to reapply it.
Ramblin Man, I was quoted £850,for what you describe. Do you mind me asking ifvthatviscin the ball park of what you paid? |
Good to know, I’ve always used a fine covering of Dinitrol ML and then overcoat with Dinitrol 4941 as AFAIK on its own the 4941 was just a coating. Do you happen to know which new product he’s referring to? wouldn’t mind doing the Skoda. The main reason for Lanoguard on the L405 is just the ability to remove it / see through it when it comes to selling it, as above I worry with anything that’s black that people would get nervous that it’s hiding something or that’s it’s a particularly rusty example to require it. There’s not as much on the L405 to cover to it’s easy work, I make a habit to do it whenever I work on it. I buy Lanoguard when they have a sale ![]() Previously George a 2007 MY07 Java Black VSE 3.6 TDV8 Previously a 04 MY04 Defender 90 ![]() |
I'm not sure what particular product he was referring too. Hopefully there is info on the Dinitrol site. My plan was to ask him to take a series of photos before and during the application process so I will have a record to prove the chassiscwas in good order and not applied as a cover up. |
I think it’s different if it’s done by a reputable outfit, presumably they would want anything rectified prior given its their own reputation on the line as well vs my lathering it with something on my drive |
