Home > Technical (L322) > Suspension calibration & air spring supply code issues |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2470 |
If the FR airspring is leaking then that corner is likely not getting to full off-road height which would then be the cause of the high voltage reading compared with the LF. If the sensor was faulty then the vehicle wouldn't lower over time, it would just sit lower all the time.
21st Jan 2023 11:36pm |
ukengr93 Member Since: 17 Jan 2023 Location: Cincinnati, Ohio Posts: 10 |
Update: I actually pulled the link below from this site in research as the inability to calibrate just does not make any sense since I clear all fault codes prior to attempting calibration. I think the Foxwell NT510 which I have is good for everything but calibration feature as this post from D3Jon points out same error problem I am having preventing calibration to move forward with cross link valve function when trying to calibrate ride height. I may be stuck laying out the cash for Gap tool. Frustrating since Foxwell does 99% of everything else very well it seems. And, I use it all the time for my other vehicles. I only laid out $65 for the Rover Software package for it.
22nd Jan 2023 3:21am |
Update: Replaced both front air spring strut assemblies with OEM from Atlantic British. Root issue seemed to be faulty passenger air strut assembly. As suspension fault/codes no more and vehicle riding very well and no sag/droop on that side any longer. I inspected the unit and couldn't really pinpoint any real cause upon removal. Other than some water was in the bag. They were remanufactured Arnotts that were removed, so it was a good move anyway getting new baseline condition quality units installed. I went & ordered GAP IId tool yesterday so I can perform calibrations. Noticed lower control arm bushings in need of replacement while doing this job so front-end remaining suspension rebuild next on the docket.
6th Feb 2023 10:31pm |
