Home > Technical (L322) > P-1173 - which side is the RH side
herman maire
Canada
I am still trying to track down a engine harshness issue, I have the fault code P1173.
I do know it says its a lean/rich fault on the RH side, is the RH bank side ( when sitting in the truck ) on your right?
Or in the UK, the drivers side, correct.
I just purchased 2 new OEM O2 sensors and I really hope this fixes my problem.
Thanks 2003 RR 4.4 only 40k miles (current)
2004 RR 4.4 ( just sold)
2000 RR 4.6 (sold)
1959 series 2 109
1956 series 1 1956
Post #62629 4th May 2011 3:21pm
pretlove
fingers crossed mate "RANGEISM WILL NOT BE TOLERATED"
Post #62632 4th May 2011 3:39pm
letsavit2
United Kingdom 2004 Range Rover Vogue Td6 Java Black
Look at RAVE and find something you know on the range rover that is noted as right side.
Good Luck... 2004 black Vogue TD6
Post #62642 4th May 2011 6:29pm
dan_uk_1984
Re: P-1173 - which side is the RH side
Thanks
I take it you've checked the PCV system? All 4 hoses? A vacuum leak will manifest itself as a fuel trim error due to the unmetered air....
Post #62648 4th May 2011 7:00pm
SteveMFr
Site Sponsor
With cars, R and L is always in the direction of travel - hence RHD and LHD Razz
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #62783 5th May 2011 6:37pm
herman maire
Canada
Steve, thats great.... I will remember that for many years to come. 2003 RR 4.4 only 40k miles (current)
2000 RR 4.6 (sold)
1959 series 2 109
1956 series 1 1956
Post #65282 22nd May 2011 5:38pm
herman maire
Canada
Wanted to update this.
I have had my engine compression checked. The engine appears to be in perfect health, the gauge that I used was not the best but all the cylinders were between 175psi and 180psi on a hot engine. I was quite please with the results.
So, theres no chance that the engine harshness is coming from a damaged cylinder.
I purchased 2 brand new O2 sensors for the RHD side. Once installed, I disconnected the battery to reset the check engine.
With the check engine light off, the engine is still just as harsh.... within 30KM the check engine is back on.
I have a appointment with the land rover dealer this tuesday..... if they cant figure out what the problem is, I am really at a loss as to what to do.
I have checked the following-
spark plugs
coil packs
new O2 sensors
all intake piping ( maybe theres still something I am missing)
MAF
Big Cry Big Cry 2003 RR 4.4 only 40k miles (current)
2000 RR 4.6 (sold)
1959 series 2 109
1956 series 1 1956
Post #65285 22nd May 2011 5:50pm
dan_uk_1984
You didn't answer my question above... Were all 4 PCV pipes replaced?
Post #65288 22nd May 2011 6:02pm
herman maire
Canada
Sorry Dan, I forgot.
I checked all the hoses and they are all fairly new..... No marshmellow pipes here. It also idles very, very smooth. Its only when its under load that if feels very harsh and you can feel vibration in the floor pan with your feet from 2000rpm-up
Or when I rev it in neutral you really feel something around 4000RPM.
I would check the PCV valve but if I remember correctly when I changed that unit on my other MK3 RR you cant open them.
I guess I can just change it just to be sure. Do you think a faulty valve can be the problem?
I am wondering if when the water pump was changed a few months ago, if its possible the metal emissions pipe were poorly installed if that could cause the harshness.
Thanks again for your help. 2003 RR 4.4 only 40k miles (current)
2000 RR 4.6 (sold)
1959 series 2 109
1956 series 1 1956
Post #65295 22nd May 2011 6:37pm
dan_uk_1984
On your other post I linked to a BMW forum where the guy was having similar problems PLUS a lot of noise coming from his PCV system.
There are 4 pipes in your PCV system, the two easy ones on the top, then two difficult ones which run down the back. Then as you say, there is the valve itself. BMW owners generally experience failure of the rubber diaphragm between 80-120K and I imagine we should expect to see the same on our cars.
The PCV valve itself is not massively expensive (I think I paid £60-£70) bit it's a pig to change and the hour rate can add up depending on which garage you use.
D
Post #65299 22nd May 2011 6:56pm
Might be worth a look for the PCV http://www.rswsolutions.com/index.php?opti...;Itemid=78
Post #65307 22nd May 2011 8:23pm
herman maire
Canada
I guess its possible it has something to do with the PCV system....
I will say that on my other MK3 RR that had the check engine light last summer, all the PCV pipes completely failed, other than the check engine light, it still ran very nice..... smooth idle, normal MPG and no engine harshness.
I dont get it Big Cry 2003 RR 4.4 only 40k miles (current)
2000 RR 4.6 (sold)
1959 series 2 109
1956 series 1 1956
Post #65425 23rd May 2011 3:53pm
dan_uk_1984
There are two halves to the PCV system though, hence the four pipes. Did you replace/check all four? Or just the two on the top?
Post #65426 23rd May 2011 3:56pm
herman maire
Canada
Hi Dan,
On my MK3 RR last summer, I changed all 4 pipes + valve. I cracked open the old valve and the valve was in great shape.
On my current MK3 RR, I checked all 4 pipes and they are all in near new condition. Unless the valve is complete faulty ( very possible ) or something is plugged in one of the pipes ( very possible ) it looks good.
I will get a new valve and clean out the cyclone and pipes .
I will see what the dealer has to say tomorrow, I really hope they figure out something..... 2003 RR 4.4 only 40k miles (current)
2000 RR 4.6 (sold)
1959 series 2 109
1956 series 1 1956
Post #65456 23rd May 2011 5:02pm
herman maire
Canada
Just wanted to update this,
I went to the dealer last week to have a 4 wheel alignment+ suspension calibrated ( HUGE difference) , rear hub bushings and the check engine light checked .
$1300 later , about 20km from the dealer the check engine comes on with the same error code P1173!!!
The engine is still just as harsh to the point where you feel it in the floor pan with your feet.....
The truck is handling GREAT, almost agile. Engine has plenty of power and the compression is still perfect BUT the engine harshness is taking any enjoyment out of driving such a beautiful truck.
Any other suggestions ? Maybe a BMW specialist this time? I am at a loss as to what to do...... I just want this truck running like it did in january. 2003 RR 4.4 only 40k miles (current)
2000 RR 4.6 (sold)
1959 series 2 109
1956 series 1 1956
Post #67964 10th Jun 2011 2:07am
