Home > Technical (L322) > P-1173 - which side is the RH side |
pretlove Member Since: 10 Feb 2011 Location: Bas vegas Posts: 1865 |
fingers crossed mate "RANGEISM WILL NOT BE TOLERATED"
4th May 2011 3:39pm |
letsavit2 Member Since: 16 Oct 2010 Location: essex Posts: 854 |
Look at RAVE and find something you know on the range rover that is noted as right side.
4th May 2011 6:29pm |
I take it you've checked the PCV system? All 4 hoses? A vacuum leak will manifest itself as a fuel trim error due to the unmetered air.... |
4th May 2011 7:00pm |
With cars, R and L is always in the direction of travel - hence RHD and LHD
5th May 2011 6:37pm |
herman maire Member Since: 28 Nov 2010 Location: up north Posts: 51 |
Steve, thats great.... I will remember that for many years to come. 2003 RR 4.4 only 40k miles (current) 2004 RR 4.4 ( just sold) 2000 RR 4.6 (sold) 1959 series 2 109 1956 series 1 1956 |
22nd May 2011 5:38pm |
Wanted to update this.
22nd May 2011 5:50pm |
You didn't answer my question above... Were all 4 PCV pipes replaced? |
22nd May 2011 6:02pm |
Sorry Dan, I forgot. I checked all the hoses and they are all fairly new..... No marshmellow pipes here. It also idles very, very smooth. Its only when its under load that if feels very harsh and you can feel vibration in the floor pan with your feet from 2000rpm-up Or when I rev it in neutral you really feel something around 4000RPM. I would check the PCV valve but if I remember correctly when I changed that unit on my other MK3 RR you cant open them. I guess I can just change it just to be sure. Do you think a faulty valve can be the problem? I am wondering if when the water pump was changed a few months ago, if its possible the metal emissions pipe were poorly installed if that could cause the harshness. Thanks again for your help. 2003 RR 4.4 only 40k miles (current) 2004 RR 4.4 ( just sold) 2000 RR 4.6 (sold) 1959 series 2 109 1956 series 1 1956 |
22nd May 2011 6:37pm |
On your other post I linked to a BMW forum where the guy was having similar problems PLUS a lot of noise coming from his PCV system.
22nd May 2011 6:56pm |
Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470 |
Might be worth a look for the PCV http://www.rswsolutions.com/index.php?opti...;Itemid=78 |
22nd May 2011 8:23pm |
I guess its possible it has something to do with the PCV system....
23rd May 2011 3:53pm |
There are two halves to the PCV system though, hence the four pipes. Did you replace/check all four? Or just the two on the top? |
23rd May 2011 3:56pm |
Hi Dan, On my MK3 RR last summer, I changed all 4 pipes + valve. I cracked open the old valve and the valve was in great shape. On my current MK3 RR, I checked all 4 pipes and they are all in near new condition. Unless the valve is complete faulty ( very possible ) or something is plugged in one of the pipes ( very possible ) it looks good. I will get a new valve and clean out the cyclone and pipes . I will see what the dealer has to say tomorrow, I really hope they figure out something..... 2003 RR 4.4 only 40k miles (current) 2004 RR 4.4 ( just sold) 2000 RR 4.6 (sold) 1959 series 2 109 1956 series 1 1956 |
23rd May 2011 5:02pm |
Just wanted to update this,
10th Jun 2011 2:07am |
