Home > Technical (L322) > td6 rear diff swap
bembo449
United Kingdom 2002 Range Rover Vogue Td6 Adriatic Blue
td6 rear diff swap
searched and looked in wiki , no info on swapping the rear diff , looks to me like 18 bolts and pull the half shafts far enough out to clear the cups , any thoughts / experience ?
Post #654077 19th Jan 2023 11:02pm
The WM for the early fatty in the WIKI is in fact just a description and operation manual, if you look at the later WM in the WIKI there is the removal procedure which will be very similar...
I haven't watched it but this might help...
And I take it you are aware the TD6 has a different final drive ratio to the petrol so if you are using second hand make sure it's the right ratio...
Thumbs Up Pete
Post #654116 20th Jan 2023 10:21am
