Home > Technical (L322) > FBH Changeover Valve
Westridge177
2011 Range Rover Vogue SE TDV8 Buckingham Blue
Hi can anyone advise on accessing the FBH changeover valve on a 2011 TDv8
Thanks
Phil
Post #654022 19th Jan 2023 3:19pm
Discotigger
There's loads of info on the FBH Changeover Valve on this thread:
https://www.fullfatrr.com/forum/topic61127.html
Give it a good read through, it covers loads on the Heating System. Thumbs Up
Post #654026 19th Jan 2023 4:37pm
Westridge177
Thanks for taking the time to reply.
I've read through the linked post, variously it talks about the valve being on the left hand or right hand of the engine bay (maybe it depends upon how you are looking at it!
If I may repeat the original question I would be interested to hear from anyone who has repaired this valve on my specific model. How did you access it?
Post #654032 19th Jan 2023 5:38pm
Discotigger
The FBH Changeover valve is located on the inner wheel arch on the LHS of the vehicle if you are looking from the front of the vehicle into the engine bay. It is not difficult to access, but it is fiddly to remove from the mounting plate.
Can I ask what problem you have that requires needing access to the FBH Changeover Valve?
I'm afraid that there are no repair kits suitable for the FBH Changeover valve, it is a case of getting a new one or a 'functional' second hand one.
Post #654084 20th Jan 2023 12:00am
Westridge177
Thanks again for responding, I will take a look for it tomorrow. When you say on the inner wheel arch is it accessible from the top of the engine bay, underneath or through the wheel arch. My symptoms are that it is not closing hence the fbh is trying to heat the whole block during parking heat operation. My understanding was that half of the heater (dual) valve kits would effect a repair but I’m here to learn.
Post #654086 20th Jan 2023 12:23am
Discotigger
Hi, sorry for the delay in responding. The FBH Changeover Valve is accessed from the engine bay. If you have a look on the wheel arch to the LHS of the engine you will see it bolted to the arch. There aren't any specific repair kits for the Valve, most kits are for repairing the twin heater control valves. The Changeover Valve is different in that it has a different piston setup inside. I managed to hunt down a cheap genuine valve, after having purchased a 'repair' kit which didn't work.
Post #654225 21st Jan 2023 10:19am
Westridge177
Thanks again for your input and the info that you can’t repair using seals from the dual valve kit. I’ve seen the genuine valve at over £300 and copy parts at 1/10th of that. As it’s not exactly a crucial part I’m tempted to have a punt.
Any thoughts?
Post #654233 21st Jan 2023 11:22am
That's a dilemma, how long does it take to change, if not long maybe worth a punt... Thumbs Up Pete
Post #654237 21st Jan 2023 11:36am
Westridge177
That’s a good point. I will have a proper look at the location before ordering
Post #654244 21st Jan 2023 12:06pm
Discotigger
That Valve, part no. LR016848 will fir your Fattie and should work ok. It's the same Part No. as the replacement valve I got when I had the problem with my heater. I was lucky enough to get a genuine one of fleabay for £140.00, but the cheaper ones will be pretty much the same quality as the genuine article.
Fitted it and all good. You will need to remove the valve with it's mounting bracket and swap the bracket onto the new valve. You will need to be a bit careful not to lose too much coolant from the disconnected hoses as bleeding the system can be a bit fiddly. You can also top up any lost coolant by pouring fresh coolant into the disconnected hoses prior to connecting to the valve.
Post #654266 21st Jan 2023 3:27pm
jaguar3
Estonia 2011 Range Rover Vogue SE 4.4 V8 Baltic Blue
Why you dont like the engine block is also preheated?
I doing exactly the same thing with my valve, fix it in open position forever.
Post #654389 22nd Jan 2023 8:55pm
AdrianL322
Norway 2012 Range Rover Vogue TDV8 Buckingham Blue
I also want to fix it permanently in the open position, how did you manage that? Just disconnecting the valve? 2012 Range Rover TDV8 4.4
Post #654646 24th Jan 2023 11:44pm
jaguar3
Here you can read how I do it
https://www.fullfatrr.com/forum/topic41448-45.html
Post #654651 25th Jan 2023 5:46am
Westridge177
Because when heating the block the cabin heater takes too long to become effective.
Because with the fbh running for longer to assist the block the two heater control valves are overridden and stay open hence your hater controls are not effective. This is a common complaint on the Range Rover.
Because here in the uk we never get temperatures that need the block heated. The vehicle is set up to kick this in at -20c.
Post #655059 29th Jan 2023 2:43pm
jaguar3
Yes, thats true, RR have too big cabin, engine block, wrong air direction, so 20min (with older soft 30) heating time is not enough.
Yes, with -20 it will heat the block automatically. We also here almost never get -20 and below, but what about -10, -15, -19? Its already cold start and hard for the engine. To avoid that, I fix it permanently in open position to pre-heat the block.
Two heater control valves always stay open until you have too warm in the cabin and need to reduce the heat (FBH will anyway shut off in this case. FBH can not work with closed valves due coolant circulation will reduced/blocked by these valves).
In my opinion, there should be double battery and adjustible heating time, up to 1h. Only then you will get perect pre-heating system, for the cabin and engine block. Jump in and drive.
And even then, the direction of airflow is set to the windscreen only. Due cold windscreen, the air also cool down and not heat ut the cabin well. All must be open.
By the way, dont think if you will restore the changeover valve, you will get warm cabin. No, even when 100% heat directed to the cabin, it stay quite cold due short working time (with -5 already). Maximum, you will get windscreen open, but not warm cabin. And there is nothing to do with that, weak system. Thatwhy I rebuild mine compleatly.
Post #655062 29th Jan 2023 3:45pm
