Home > Maintenance & Mods (L322) > air pipe problem
littlecub
Australia 2003 Range Rover HSE Td6 Epsom Green
air pipe problem
On my TD6 the connection from the guard to air filter has come off.
Car is running fine but would like to re-attach the pipe.Can anyone enlighten me as to how its connects.
Dont know if I am missing a connector piece or not.
TIA
littlecub
Post #653857 18th Jan 2023 1:03am
Danb_220_2019
United Kingdom 2012 Range Rover Vogue SE TDV8 Fuji White
I'm no expert on the TD6 architecture, but that looks... Broken.
Post #653860 18th Jan 2023 7:48am
The pipe looks fine to me. The rubber open end of the pipe simply slides over the plastic top bit. Lubrication helps. No clips or anything involved.
I got so fed up of this pipe l replaced it with a length of 90mm día flexible hose and two worm drive clips. Never had an issue since. Thumbs Up
Post #653887 18th Jan 2023 1:06pm
littlecub
Thanks for the tip Nicedayforit.
littlecub
Post #653927 18th Jan 2023 6:47pm
Merchy
same advice as above from me, mine was not a tight fit, so where the pipes overlap I simply drilled a tiny hole through the pipes once they were correct position and fitted a small self tapper screw, no problems since then
Post #653930 18th Jan 2023 6:56pm
