Home > Maintenance & Mods (L322) > air pipe problem |
Danb_220_2019 Member Since: 02 Jan 2023 Location: Suffolk Posts: 262 |
I'm no expert on the TD6 architecture, but that looks... Broken. |
18th Jan 2023 7:48am |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3979 |
The pipe looks fine to me. The rubber open end of the pipe simply slides over the plastic top bit. Lubrication helps. No clips or anything involved.
18th Jan 2023 1:06pm |
littlecub Member Since: 02 Apr 2013 Location: Ulverstone,Tassie Posts: 325 |
Thanks for the tip Nicedayforit.
18th Jan 2023 6:47pm |
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1210 |
same advice as above from me, mine was not a tight fit, so where the pipes overlap I simply drilled a tiny hole through the pipes once they were correct position and fitted a small self tapper screw, no problems since then |
18th Jan 2023 6:56pm |
