Home > Maintenance & Mods (L405) > Jacking up a 2019 L405
Macpaul
2019 Range Rover Vogue SE 2.0 PHEV Siberian Silver
Even the first jack the tyre shop had wasn’t tall enough.
They brought in the six ton truck one.
Answer seems to be jack up the lower suspension arm, not the actual chassis.
Post #653862 18th Jan 2023 8:31am
As I said before, it is NOT advised to jack on a suspension arm, the arm moves through an arc when jacked, it also leaves the whole corner under compression, it is very easy for the jack to slip off, this can damage parts of the car or even worse parts of you if you happen to be in the way when it lets go, it will not give any warning, it just spits the jack out...
The answer is to buy a jack with enough lift or leave it to someone else.... Thumbs Up Pete
Post #653868 18th Jan 2023 9:21am
Gremlin500
Interesting thread.
@Pete (Haylands):
You mention jacking under the lower suspension arm, (if you know what you are doing).
Can you expand on this please? Presumably for example, one could use a big 3Te high-lift jack on the “official” jacking point, then gently jack under the suspension arm with a smaller jack, to lift the hub up to a more comfortable working height for access, or for whatever other reason? (i.e. not taking the weight of the vehicle on the arm, only the weight of the hub & suspension). Question
Axle stands always a must, of course! Thumbs Up “If it ain’t broke, don’t fix it” -where’s the fun in that?
Post #653869 18th Jan 2023 9:27am
Yes my advice is... don't do it...
The suspension arm rises and falls through an arc that's direction is across the car
The jack rises through an arc the other way when in situ...
This makes it very dodgy, the suspension assembly is under compression and wants to spit the jack out, as the jack rises it gets worse and worse.
Using another jack to slightly raise the corner to clear the wheel from the ground will work, but again it's not recommended...
If you do take that route make sure the car is on level hard ground, at least one other wheel is chocked, the boot is open (or a door) to stop the suspension levelling, and you have an axle stand underneath a jacking point, at the least throw the spare wheel under the sill...
It's not fun if it falls off the jack and you can do a lot of expensive damage, or end up badly injured.
Most breakdown services will change a spare wheel so best to leave it to them if you can... Thumbs Up Pete
Post #653941 18th Jan 2023 7:39pm
MarkMurphy
United Kingdom 2002 Range Rover Vogue 4.4 V8 Zambezi Silver
Yes, Don't be like me, on boxing day i got crushed by mine, luckily neighbour heard me, ended up with just a smashed face, and All of my ribs broken, VERY VERY scary.
Post #654023 19th Jan 2023 2:38pm
Yikes - was that with a trolley jack or the scissor jack from the boot ?
Post #654025 19th Jan 2023 2:59pm
caymanblack
Bloody hell, thats terrible. Scissor jack i bet. overfinch modified
Post #654044 19th Jan 2023 6:41pm
MarkMurphy
Was with trolley jack, but with the motion on the spanner, it rocked off, i had axle stands too, but they just fell over, my drive is not straight.
Post #654048 19th Jan 2023 6:57pm
That is indeed scary.
The scissor jack is notoriously weak, but sounds like you had taken reasonable precautions.
I hope you feel better soon.
Post #654050 19th Jan 2023 7:20pm
TJH1985
Wishing you a speedy recovery Mark!
Jacking up cars, and being under axle stands as well as stories from my dad of cars falling, is exactly what eventually lead me to this purchase!
 Sold - Bell a 2015 MY16 Loire Blue Autobiography 4.4 SDV8
Previously George a 2007 MY07 Java Black VSE 3.6 TDV8
Previously a 04 MY04 Defender 90 Sad
Post #654064 19th Jan 2023 8:50pm
MarkMurphy
Thank you, That's an awesome bit of kit!
Post #654076 19th Jan 2023 9:57pm
Now that's how to jack up a fatty... Thumbs Up Bow down Thumbs Up
(On a side note, do you not have any windows in your house...??) Pete
Post #654112 20th Jan 2023 8:56am
caymanblack
still not sure I would get under that. overfinch modified
Post #654156 20th Jan 2023 4:22pm
The ones I have seen have a mechanical lock to prevent it dropping unexpectedly... Thumbs Up Pete
Post #654158 20th Jan 2023 4:36pm
TJH1985
Yeah it’s got dual safety locks on it Thumbs Up Sold - Bell a 2015 MY16 Loire Blue Autobiography 4.4 SDV8
Post #654170 20th Jan 2023 6:02pm
