Home > Technical (L322) > Screen washing not washing |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35268 |
lift the bonnet and you'll see the tubing . ... - .- -.
9th Jan 2023 9:17pm |
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1465 |
Forgive stating the obvious, but have you used a needle in the jets, in case they are clogged with dirt or the previous owner used tap water instead of screenwash, and could be limescaled up? 2015 Range Rover Autobiography 4.4 SDV8 |
9th Jan 2023 9:43pm |
Mike_A4 Member Since: 01 Jan 2023 Location: Suffolk Posts: 34 |
Duly forgiven Gary, although it required a bit of compressed air to do the trick. Typically we thought of that after the airbox had been removed to access the reservior.
10th Jan 2023 3:51pm |
This actually gets much sillier.
13th Jan 2023 3:34pm |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4302 |
Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
13th Jan 2023 4:01pm |
Discotigger Member Since: 12 Feb 2013 Location: Cumbria Posts: 804 |
There should be a plastic panel that clips in over the battery in the engine bay that has two clips to hold and route the washer pipes to stop them getting pinched by the bonnet. It sounds like either it's missing on your FF or has been broken.
13th Jan 2023 5:21pm |
There's a panel...? I might have to take a photograph. |
13th Jan 2023 5:32pm |
See the thread in my edit above.
13th Jan 2023 5:33pm |
I am so missing one of those! Does it have a part number? |
13th Jan 2023 5:36pm |
It probably does, it's dark and raining here at the moment, but I'll have a look in the morning and get you the part number if it's on it. |
13th Jan 2023 5:39pm |
Top chap, thank you. |
13th Jan 2023 5:40pm |
Hi Mike_A4.
14th Jan 2023 2:23pm |
Brilliant, thank you. I'll get one on order this week... as soon as the alternator is sorted. Now the bonnet has been up and, more awkwardly, down several times this weekend, the need is obvious! |
15th Jan 2023 1:22pm |
telly-addict Member Since: 22 Mar 2019 Location: Morayshire Posts: 138 |
I had the same problem and it seems I'm missing that plastic bracket too! Cam
17th Jan 2023 6:29pm |
