Home > Maintenance & Mods (L322) > Tdv8 4.4 front differential unit change, advice saught. |
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1260 |
Have you downloaded the workshop manual?
17th Jan 2023 9:57am |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3550 |
If you download the turbo drain mod doc, the diff removal is included
17th Jan 2023 3:58pm |
diesel Dave Member Since: 14 Aug 2015 Location: Stockport Posts: 462 |
Once everything is unbolted, prop removed and drive shafts out it does wiggle out through the side of the subframe, its a tight fit but it will come out, just watch you don’t trap you fingers getting it out as its quite heavy. Good luck |
17th Jan 2023 10:22pm |
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2035 |
thanks guys... when the weather turns, I will get on with the job. and report back. |
18th Jan 2023 12:54pm |
