Home > Technical (L322) > 2011 4.4 tdv8 high tick over and viscous fan on all the time
Seancod
Wonder if anybody has any ideas on the above. I can’t find anything on the search. I drove back from town today a 15 mile journey, which I could hear the viscous fan running all the time. When I got home and put it in neutral, the tick over was at 1100 rpm. I left it running for a couple of minutes and the fan stopped but the tick over stayed up at 1100. The temperature gauge was at it usual position and I have seemed to have used more diesel than I would expect. Plugged in the gap obd tool and did not come up with any faults. Does this ring any bells with anyone? TIA
Post #653588 14th Jan 2023 6:20pm
Phoenix
Read the live values for all temperature sensors, including transmission - I know you say the coolant temp. was showing 'normal', there will be a high temperature, or reported high temperature somewhere.
The engine cooling fan running at 100% lockup will chew through fuel like Bugs Bunny through carrots... the high tickover RPM is to aid powertrain cooling.
Post #653594 14th Jan 2023 8:13pm
Seancod
Thanks for that, makes sense, I will investigate tomorrow.
Post #653595 14th Jan 2023 10:03pm
Phoenix
Best to do with a completely cold car, that way any values that are not at ambient or close to it will immediately stick out.
Post #653596 14th Jan 2023 10:13pm
Seancod
Thanks Phoenix for putting us on the right track. Transmission all checked out ok but turned out to be an issue with the air con. Must need a regas and comes on in auto mode. Switched off and all back to normal, big relief, thought this could be big money.
Post #653613 15th Jan 2023 12:06pm
JayGee
Don't assume it's just a regas as the compressor is a common fail on these cars. Plenty of info here much of it supplied by Phoenix's expertise. 2012 TDV8 Vogue (L322)
Post #653615 15th Jan 2023 12:13pm
Seancod
Yes, could be a compressor fault, will check it out when the weather gets better. At least I can still use it just with no AC.
Post #653629 15th Jan 2023 2:32pm
