Home > Technical (L322) > Can leak off leaks cause manifold issues? P023D
peternicholls
Been replacing injectors, and the leak off / spill hose assembly. Had terrible trouble with clips not keeping the hose attached on injectors. Massive spills. Lost about 5 gallons… ok that points to a lot of spill, but they are all old injectors as I can’t yet afford all new, who could right now?!
Anyway, could this fuel have caused other issues? I’m getting P023D ‘MANIFOLD ABSOLUTE PRESSURE - turbocharger boost sensor A correlation”
Also, what is ‘A’ referring to? ICarsoft is non specific like that. 2007 VOGUE TDV8 3.6
Post #653557 14th Jan 2023 12:46pm
peternicholls
SOLVED.
Rear hoses to manifold were not clamped on and were loose! No more issues, 2007 VOGUE TDV8 3.6
Post #653592 14th Jan 2023 7:57pm
