Home > My Range Rover > Finally, A Full Fat.
Page 4 of 5 <12345>
Thumbs Up ... - .- -.
Post #653447 13th Jan 2023 1:19pm
mgrover
anyone got the front drop links part number? Rang LR, they seemed to think it was £200 for 1. Its actually a sport Sad
Not anymore, 4.4 TDV8 now Very Happy
Post #653454 13th Jan 2023 2:32pm
DrRob
Site sponsor Advanced Factors for your parts.
Discount code: AF4LRP Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #653470 13th Jan 2023 4:03pm
mgrover
Needed it today, went and got it locally from a specialists.
But I feel like I've made a big mistake installing the air strut. I cut off the old pipe back,ie the buldge is cut off as well, Is that an issue because I have a leak from the connection? Its actually a sport Sad
Post #653476 13th Jan 2023 4:50pm
mgrover
Pushed the pipe in some more and that seems to have sorted the leak.
Did the other side as well
Got an error for the left side height sensor, will see if it's still a thing after calibration. Could be cause I let the hub drop to the floor when I first did it, which might have strained the sensor so lesson learned Its actually a sport Sad
Post #653563 14th Jan 2023 2:43pm
mgrover
error still persists for the left hand height sensor.
could I have broke it letting the hub drop like that? oddly enough its all "working" fine, ie everything is level with no issues and the output in iid matches the right side when on level ground.
or might it just need repositioning?
edit:
if i do replace, is OEM the only way forward with these? i know for sensors RR's can get really antsy if things aren't OEM. Its actually a sport Sad
Post #653707 16th Jan 2023 9:34am
Changed a front bag on my last 322, suspension was at full extent of it's travel with the bag removed and no adverse effects... could be yours didn't like it though...
Depends how long you are going to keep it, the cheap pattern parts don't last anywhere near as long as a genuine one... Thumbs Up Pete
Post #653714 16th Jan 2023 10:56am
mgrover
am going for 5 years min. or till i get bored and try to buy a L405 Laughing
the annoying thing is it seems to be functioning fine so would really rather not mess with it. ill get the wheel off when I finish work on the M5 and see incase it ended up in the wrong position somehow.
the drop was sudden so wondering if it "yanked" anything internally.
i guess if i end up replacing ill do the pair. Its actually a sport Sad
Post #653716 16th Jan 2023 11:08am
No need to do the pair, if the other still works with no faults just leave it alone... Thumbs Up Pete
Post #653759 16th Jan 2023 8:40pm
mgrover
another day another problem, the drivers side door doesnt want to open now from either the inside or outside.
i mean initially it unlocked and it opened, but then wouldn't latch to shut. so in my stupid genuis, i close it and locked the car, but now it won't open from inside or outside.
the inside handle does "unlock" the door, but refuses to open it. am guessing something went due to this lovely cold weather.
somehow i doubt both interior and exterior cables have snapped. maybe just frozen? Its actually a sport Sad
Post #653784 17th Jan 2023 11:40am
IIRC you can get in via a rubber bung that is accessible with the rear door open, thread on here somewhere.... Thumbs Up Pete
Post #653788 17th Jan 2023 12:17pm
Having said that a search reveals this has happened numerous times when cold, the electric solenoid cannot overcome the frozen lock, deicer or time should sort it... hopefully... Pete
Post #653790 17th Jan 2023 12:20pm
mgrover
boiling water did trick
funnily enough my e39 m5 was playing up as well, with the inside latches not working haha
probably the same mechanism. Its actually a sport Sad
Post #653791 17th Jan 2023 12:25pm
Thumbs Up Pete
Post #653793 17th Jan 2023 12:31pm
mgrover
dumb question but I assume it has to be the special VDS height sensors? because a friend of mine has a box of them but am pretty certain it's not "VDS" because its old BMW ones. Its actually a sport Sad
Post #653881 18th Jan 2023 12:17pm
Page 4 of 5 <12345>
