Home > Maintenance & Mods (L405) > Flushing the dynamic response system ( pump circuit ) |
Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1421 |
@Fisha,
11th Jan 2023 7:15am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35265 |
it does..
11th Jan 2023 7:26am |
knwatkins Member Since: 11 Sep 2020 Location: Poole, Dorset Posts: 768 |
A great write up for the community. Thanks Fisha 👍 Kev
11th Jan 2023 7:53pm |
horse86 Member Since: 09 Dec 2014 Location: PA Posts: 860 |
How much did you need to flush it fully? 2-3 liters? Nice write up. I been thinking about flushing mine. So this will flush the lines but no necessarily the ACE block correct? so long as you don’t let air in (make sure to keep the rez topped off while engine is running) you are good? I’m guessing air in the line would be a huge “oh F!”? Does this system not need to be pressurized when a bleed like this is done? I need to find where and what options for fluid I have here in the states…the LR fluid is impossible to come by 2014 FF Autobiography 5.0 SC 2008 FFRR (sold) 2008 BMW M5 |
5th Feb 2023 3:49am |
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1350 |
Sorry, here comes a long post …
6th Feb 2023 9:26am |
Thorough reply! Lol
8th Feb 2023 3:20am |
baz000000 Member Since: 01 Apr 2022 Location: Shropshire Posts: 125 |
I did a reservoir and fluid change today trying out a suction method on the return line as I have done this with success on other car PAS fluid changes in the past. The Range Rover stability control circuit doesn't allow for sucking through so I did have to run the engine in 3 second bursts (a 500ml reservoir fill). To keep the oil in the reservoir ahead of pumping I simply didn't remove the red push in stopper that comes with the new unit.
23rd Mar 2024 7:00pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8190 |
When I replaced both front and rear pipes on mine
23rd Mar 2024 7:51pm |
So just as a follow up to this. Its been 20 months since doing the flush pictured in the first post, and I never got round to changing / flushing the oil since then. I dabbed my finger into the tank now and then over time to see if it were milky, but it never looked like it.
9th Sep 2024 7:44am |
hmallett Member Since: 21 Jan 2024 Location: Mid-Wales Posts: 62 |
It's nice to see a follow up to a post after some time, so that people who later find it can be reassured that the fix worked well in the long term. |
9th Sep 2024 9:10am |
