Home > Maintenance & Mods (L405) > Flushing the dynamic response system ( pump circuit )
fisha
So a while back I put water into the dynamic response fluid reservoir. I flushed it out soon after, and after a few weeks flushed it out again and I thought I would show some pics in case anyone else wants/needs to do similar down the line.
As yet I haven’t a means to put the valve block into a bleed mode. I need a better diagnostic tool than the iidtool which I don’t believe has the function. So that leaves flushing what I can, and here is how it went.
Update with fluids I believe are correct from my web searching:
LR Part number: STC50519 ( I think )
Texaco 33270 / Cold Climate PSF 14315. ( I understand this to be the original fluid standard which others meet )
GM 9985835
ZF TE-ML
Other UK Sources which list as suitable and easily had in the UK cheaper than LR:
West Way Oils Cold Climate ACE / PAS Fluid ( I used this on the 1st flush )
Smith and Allan Cold Climate PSF ( I used this second time round as pictured)
When I originally put water in, it came out like this which was quite thick and sludgy.
Second time round, it came out still opaque, but its consistency was very much like new fluid, and had a green sheen to it ( like new fluid).
So first thing is to empty out the reservoir. I use a cheap 100ml syringe and a bit of hose to reach down into the bottom corner of the tank ( arrowed ). It takes about 250ml out to empty.
Then undo the 10mm bolt that holds the tank to the strut mount. Once undone, the tank can be pulled upwards to gain access to the pipes. The bottom pipe is the flow from the tank to the pump. The upper pipe with the 90deg bend is the return from the valve block. You only need to disconnect the return.
I found it best to undo the clip around the hose and move it away from the connector. Move it a good bit away as the plastic pipe is inserted about an inch into the hose. ( i moved it to about the dotted line )
Then you can remove the connector off the tank. Press in the latch (1), then pull outwards (2) which you might need to assist with a screwdriver as leverage. The connector needs to come away a fair distance from the tank as the pipe inside is about an inch long inside. (Dotted red line).
Then i put a blocked up piece of hose over the return pipe going into the tank.
At this point, you can wiggle out the plastic 90deg bend. I found it easier to twist it as I pulled. You wouldn’t be able to do this if the bend were still attached to the tank.
I then fitted a hose extension onto the return hose. I use a valve as it means I can close it off to minimise fluid flowing back when I disconnect it later.
And ran the extension into a catch canister with a gauge to monitor how much it was filled ( cause it fills FAST )
Reseat the tank in normal position and use a funnel to fill. I made up a funnel from a bottle as the nozzle is short. A long thin nozzle pushes too far into the tank against a filter inside and would restrict the tank filling … which you dont want as it draws it as quick as it can be filled.
At this point its ready to be filled. (I’ll update this post later with the fluids that can be used ).
Before filling, put aside about 500ml of new fluid into a different container. You need this later as the tank needs drained like at the start in order to refit the pipes … after which it needs topped back up again from that fluid which you’ve kept aside.
To refill:
- fill the tank to the top
- have someone start the engine.
- the tank level will drop instantly and quickly
- keep filling the tank as it draws
- watch the catch tank fill up till you get close to running out of new fluid.
- near sh!t yourself as the catch tank beings to fall over and try to empty itself across the engine bay Rolling with laughter
- shout to the assistant to turn the engine off
Marvel at how you saw the fluid being pushed out change from milky colour to a clear light green colour. You can see this in the catch tank the change as it filled …
And the clear fluid now in this section of the system:
To finish it off, syringe out the tank to empty it, reconnect the hoses, and then refil the the correct level using the fluid you set aside thoughtfully at the start !
To close out, this was the fluid which was in the catch tank … so even this is much clearer than where I started.
Now, I dont consider that this is the end of my efforts. There will still be some water in the system, and it’ll change towards being milky again … but far far less than before. My first flush didn’t anywhere as close to how clean the fluid being pushed out was this time, so I’m much happier about now.
Until I sort out a diagnostic kit, this is my only option.
And to clarify, throughout this, there has been no errors thrown by the car, and its driven fine throughout the time. V8 or else ...
Post #653259 11th Jan 2023 12:47am
Gremlin500
@Fisha,
Great write-up, very clear & concise, well deserves to be Wikified! Bow down Bow down Bow down Thumbs Up “If it ain’t broke, don’t fix it” -where’s the fun in that?
Post #653268 11th Jan 2023 8:15am
it does..
and its in the wiki.... Thumbs Up ... - .- -.
Post #653269 11th Jan 2023 8:26am
knwatkins
A great write up for the community. Thanks Fisha 👍 Kev
2014 L405 RR Vogue SE 4.4 SDV8 in Corris Grey
2010 L320 RRS HSE 3.0 TDV6 in Stornoway Grey
Post #653312 11th Jan 2023 8:53pm
horse86
United States 2014 Range Rover Autobiography 5.0 SC V8 Causeway Grey
Re: Flushing the dynamic response system ( pump circuit )
How much did you need to flush it fully? 2-3 liters?
Nice write up. I been thinking about flushing mine. So this will flush the lines but no necessarily the ACE block correct?
so long as you don’t let air in (make sure to keep the rez topped off while engine is running) you are good? I’m guessing air in the line would be a huge “oh F!”?
Does this system not need to be pressurized when a bleed like this is done?
I need to find where and what options for fluid I have here in the states…the LR fluid is impossible to come by 2014 FF Autobiography 5.0 SC
2008 FFRR (sold)
2008 BMW M5
Post #655649 5th Feb 2023 4:49am
fisha
Sorry, here comes a long post …
Yes, that’s how I understand it. I’m only flushing the reservoir, pump and that side of the valve block. As for air, you’ll be able to pour in from a normal gallon container fast enough to counter the draw that the pump takes from the reservoir. It draws quick, but not panic quick, so if it draws below the level of the pump, you’ll have a couple of seconds before that level goes all the way down to the pump and cavitates, which will be enough time to pour faster to refill. It wasn’t that bad to gauge how fast to pour. I bought a 5lite container for each of the flushes.
Now, I first thought that this flush wouldn’t touch any of the fluid that’s the other side of the valve block, but I’m not so sure.
I had originally thought that the system worked by the pump pushing pressure towards the valve block, then as the car rolled, the valves would open and pass that pressure onto the relevant side of the rollbar, and that each side was a closed end that the fluid pushed against … a bit like a brake line has a closed end at the caliper piston which you press against. If this were the case, then the contaminated fluid wouldn’t really have got past the valve block much as the fluid after the block has no where to go, it just sits there transferring the pressure down the line. This idea was also supported by the notion that each side of the active rollbar has a bleed valve … like a brake caliper would.
Ir order to bleed that part of the system, I would need a tool to tell the valves in the block to open to allow pressure through it, and then also another tool to create that pressure …. Which would be the pressure bottle bleed setup that you are referring to. You could thane bleed each side like a brake caliper.
However
I’ve also read that the system is not so much 4 separate pressure lines to each corner from the valve block, but more like a front loop axle loop and rear axle loop, and that the fluid flows in a circuit from the valve block through the rollbar and back to the valve block, all the time being pushed by the pressure created by the pump when the valves open. The direction of flow around the circuit changes depending on which way car is leaning and the way the valves open.
If that were the case, then it would mean that when cornering, the fluid in the lines are being mixed with the fluid in the reservoir quite well and flushing the fluid is flushing the lines too.
So at this point, I’m of the opinion that as a result of driving, I’m flushing the whole system in a roundabout way. I will definitely do another flush in a month or so, and I’ll assess whether it’s worth doing another.
As for fluid, I listed the various equivalents I found online … a lot of which came from US forums. I would say look for the texaco / GM numbers … they are the more US based versions. V8 or else ...
Post #655784 6th Feb 2023 10:26am
horse86
Thorough reply! Lol
What source did you get your fluid from in the states? Have a link. I have yet to find a decent deal and the ones I have are over seas and would cost a boatload literally to ship
Edit: just took notice that you are from EU 2014 FF Autobiography 5.0 SC
2008 FFRR (sold)
2008 BMW M5
Post #655996 8th Feb 2023 4:20am
baz000000
England 2016 Range Rover Autobiography SDV8 Loire Blue
I did a reservoir and fluid change today trying out a suction method on the return line as I have done this with success on other car PAS fluid changes in the past. The Range Rover stability control circuit doesn't allow for sucking through so I did have to run the engine in 3 second bursts (a 500ml reservoir fill). To keep the oil in the reservoir ahead of pumping I simply didn't remove the red push in stopper that comes with the new unit.
In total 3 oil fills of the reservoir were run through before the oil discharge line turned green with fresh oil so 1.5l of oil flushed the system and around 400ml was added to the reservoir to take it to the max fill line. The cars was taken on a 5 mile run and the reservoirs topped off with around 50ml of oil. The oil in the reservoir looked the same as the new, green oil, so I'm assuming the system is pretty well flushed as the car was driven enthusiastically on very a winding road.
I found it easier as a two person job to get the new reservoir coupled to the discharge line as the clamp is a strong one to open up. One person supported the bottom discharge hose while the other held the clamp open and pushed the reservoir onto the pipe. Then the second body was needed to start/stop the engine to pump the fluid.
Post #688824 23rd Mar 2024 8:00pm
When I replaced both front and rear pipes on mine
https://www.fullfatrr.com/forum/topic67828.html
I read the Workshop Manual and its 14 page, 35 point section just on bleeding the system, IMHO totally OTT for a hydraulic system. I think the reason is because JLR consider any air in the system could result in reduced handling and subsequently be a safety issue.
Pat at Gap (IID) will be adding the pump flush programme sometime soon buy I didn't need it...
From empty I filled the reservoir, it took about 3/4 of a ltr, started the engine and the level dropped significantly, I topped it up with another 1/2 ltr and there were significant bubbles in the reservoir.
Took it for a 5mile drive, provoking the ARB's to work and the system filled fine, no fault showing at all and seems to drive spot on, pretty sure there is some self bleeding going on like most hydraulic systems. I think you should be able to successfully flush the system as fisha advises. I think it will change all the oil after just a few flushes...
The reservoir with built in filter is a service item, I think every 60,000 miles so maybe wort changing it at your last flush....
Thumbs Up Pete
Post #688829 23rd Mar 2024 8:51pm
fisha
So just as a follow up to this. Its been 20 months since doing the flush pictured in the first post, and I never got round to changing / flushing the oil since then. I dabbed my finger into the tank now and then over time to see if it were milky, but it never looked like it.
When disconnecting the ACE pipes and letting fluid drain, the fluid came out clear too ... so I'm quite happy that the 2 flushes that were done did a good job of getting the old fluid out quite well. V8 or else ...
Post #699809 9th Sep 2024 8:44am
hmallett
United Kingdom 2013 Range Rover Autobiography SDV8 Firenze Red
It's nice to see a follow up to a post after some time, so that people who later find it can be reassured that the fix worked well in the long term.
Post #699815 9th Sep 2024 10:10am
Big Boy R44ROV
Superb post and excellent step by step details Thumbs Up I'm going to do this, but also change the reservoir at the same time. Any suggestions with that?
Cheets BB Thumbs Up Tony
You're always in the Censored ........it's just the depth that varies
2014 L494 5.0 S/C AB Silver
2014 L494 3.0 HSE in Chilli
2014 SL63 AMG White
Gone:
2011 5.0 L322 White (Stolen)
07 4.2 SC in silver.
06 4.2 SC in black RSE
RRS 4.2 SC in Black RSE
52 4.4 Vogue in silver
04 Mercedes CLK 320 Conv
03 4.0 V8 ES Disco in Silver
00 TD5 90 County
98 4.6 HSE in Epsom x3
97 3.9ES Disco
93 L 4.2 LSE in black
too many classics to mention !
Post #707862 30th Dec 2024 3:02pm
