Home > Maintenance & Mods (L322) > Upper rear tailgate years
Nyorks2022
Hi all
Looking to replace my rusty rear upper tailgate on my new to me facelift 2010 model , I’m seeing that the older ones don’t rust as much but seem to have a different trim below the rear window …. Where as mine does not have this
Would removing the glass and refitting mine to an older tailgate resolve this or will it need that trim can’t find a santorini black anywhere so will need to be painted no matter what it seems
Thanks all
Post #653247 10th Jan 2023 11:03pm
mjdronfield
That trim just slides out sideways. They weren’t fitted to the later cars. Likewise, the glass trim on the edges at the side wasn’t fitted to earlier cars. Supposed to stop water dripping in the boot when you open the top tailgate in the rain.
I fitted a 2007 tailgate to my 2003 car when I had that. Think I paid £55 for glass company to come and swap glass, as one was privacy glass and one not.
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #653249 10th Jan 2023 11:18pm
Nyorks2022
Great to know thanks seen a great one in grey but it’s an older one seems to be the way
Post #653251 10th Jan 2023 11:21pm
mjdronfield
As they got newer, more and more recycled steel was used….. so tended to rust a bit more. Trouble now is, the early cars are 20 years old, so those tailgates are also rusting “naturally”….
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #653255 10th Jan 2023 11:46pm
Strider
England 2007 Range Rover Vogue SE 4.2 SC V8 Zermatt Silver
Um no not really (yet) Laughing
Post #653286 11th Jan 2023 2:31pm
02 - 06 = BMW owned Best German Steel Used
06 - 09 = FORD owned Ford cut corners / quality so... Slightly Rusty
09 - 12 = TATA owned Cheap SH*T steel used so... MOST Rust.
Post #653345 12th Jan 2023 1:27am
JayGee
Any metallurgists here to identify chemical differences in German vs TATA (Indian steel) ? IME all mild steel will rust readily and enthusiastically when exposed to the elements. It's just as likley that corners cut in the paint shop are responsible. 2012 TDV8 Vogue (L322)
Post #653350 12th Jan 2023 8:41am
JCW
United Kingdom 2010 Range Rover Autobiography TDV8 Santorini Black
I’ve been wondering the same - be interested to understand why recycled steel is more susceptible to rust assuming identical prep. & paint treatment - carbon content perhaps?
With that said, there’s no doubt in my experience the earlier tailgates rust less on a like for like age basis.
I replaced a rusted 2011 tailgate with a 2004 one and there are some differences in the various wiring apertures, although nothing that can’t be overcome. It also requires the glass out, as the loom is clipped into place between the frame & the glass and extracting it with all the connectors attached would be impossible.
Post #653351 12th Jan 2023 9:34am
Strider
[quote="Cam-Tech-Craig"
09 - 12 = TATA owned Cheap SH*T steel used so... MOST Rust.[/quote]
??? So who supplies the steel now?
It cant be British Steel as most of the plants have been closed by TATA
I do think that the rot problem is a combination of poor quality control regarding steel quatity / protection prior
to painting, anti rust coating etc.
Brake pipes are a case in point, mine were like paper when i replaced them, yet my Skoda vrs, 2 years older and done more miles, b/pipes are like new.
Go figure !!
Post #653364 12th Jan 2023 2:53pm
ABY
United Kingdom 2010 Range Rover Vogue TDV8 Baltic Blue
replaced my 2010 rear rusted upper tailgate. purchased a replacement 06 on ebay and had it resprayed. The paint shop swapped over the glass and all the lekey bits and added the older rubber trim which look quite good. It cost a bit but i'm getting my money back slowly as I every time i open to boot I dont get showered with little bits of rust Thumbs Up cost wise - all in prob circa £700 2010 3.6 TDV8 Vogue
Post #653703 16th Jan 2023 10:07am
Well documented that 80's Fiat Lancia and Ferrari all suffered from rust issues due to the Italian government insisting that they used steel with a high proportion of recycled steel... this was the start of the problem, the woefully appalling rust prevention didn't help as well...
When I looked into it there are two tailgates used across the years, both are interchangeable but minor differences...
A new tailgate is £1,100 + vat.... Shocked Pete
Post #653795 17th Jan 2023 1:46pm
JayGee
It's a well documented myth
Post #653805 17th Jan 2023 3:58pm
