![]() | Home > Maintenance & Mods (L322) > Upper rear tailgate years |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7912 ![]() ![]() ![]() |
That trim just slides out sideways. They weren’t fitted to the later cars. Likewise, the glass trim on the edges at the side wasn’t fitted to earlier cars. Supposed to stop water dripping in the boot when you open the top tailgate in the rain.
Nyorks2022 Member Since: 04 Sep 2022 Location: North yorkshire Posts: 33 ![]() ![]() |
Great to know thanks seen a great one in grey but it’s an older one seems to be the way |
As they got newer, more and more recycled steel was used….. so tended to rust a bit more. Trouble now is, the early cars are 20 years old, so those tailgates are also rusting “naturally”….
Strider Member Since: 08 Jun 2015 Location: Hertfordshire Posts: 507 ![]() ![]() ![]() |
Um no not really (yet)
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16339 ![]() ![]() ![]() |
02 - 06 = BMW owned Best German Steel Used
Any metallurgists here to identify chemical differences in German vs TATA (Indian steel) ? IME all mild steel will rust readily and enthusiastically when exposed to the elements. It's just as likley that corners cut in the paint shop are responsible. 2012 TDV8 Vogue (L322) |
JCW Member Since: 13 Apr 2013 Location: Cotswolds Posts: 909 ![]() ![]() ![]() |
I’ve been wondering the same - be interested to understand why recycled steel is more susceptible to rust assuming identical prep. & paint treatment - carbon content perhaps?
[quote="Cam-Tech-Craig"
ABY Member Since: 01 Dec 2019 Location: Northampton Posts: 26 ![]() ![]() ![]() |
replaced my 2010 rear rusted upper tailgate. purchased a replacement 06 on ebay and had it resprayed. The paint shop swapped over the glass and all the lekey bits and added the older rubber trim which look quite good. It cost a bit but i'm getting my money back slowly as I every time i open to boot I dont get showered with little bits of rust |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8546 ![]() ![]() ![]() |
Well documented that 80's Fiat Lancia and Ferrari all suffered from rust issues due to the Italian government insisting that they used steel with a high proportion of recycled steel... this was the start of the problem, the woefully appalling rust prevention didn't help as well...
It's a well documented myth
