![]() | Home > Technical (L405) > New battery fitted this morning, car wont start tonight! |
Kot Member Since: 10 Mar 2021 Location: broadland Posts: 1261 ![]() ![]() |
Put it on charge with your ctek overnight, maybe when it was sold it only had partial charge?
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3146 ![]() ![]() ![]() |
Check that the terminals on the battery are tight as they can cause a no start if they’re slack.
Mca71 Member Since: 25 Sep 2018 Location: Uk Posts: 33 ![]() |
Thanks. Will have a look in the morning. It’s |
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3757 ![]() ![]() |
Believe it or not I also fitted a Halfords battery last night - you do not need to tell the car it has a new battery - I fitted mine myself - took 10 minutes and she fired up straight away and has been used on a shoot all day today with loads of stop start driving between drives and a total round trip if 150 miles without any issue whatsoever.
TJH1985 Member Since: 11 Feb 2015 Location: Nottingham Posts: 664 ![]() ![]() ![]() |
I doubt it would cause OP’s symptoms but ideally you probably should reset the BMS when a new battery is installed, from the WSM:
Sold - Bell a 2015 MY16 Loire Blue Autobiography 4.4 SDV8 Previously George a 2007 MY07 Java Black VSE 3.6 TDV8 Previously a 04 MY04 Defender 90 ![]() |
Well… here’s an update. Trickle charge didn’t work…. Jump start didn’t work…. Called my garage and they reckon possible starter motor. Got green flag out… ran diagnostics and he reckoned the battery wasn’t talking to the ecu as hadn’t been recorded properly… it’s getting towed to the garage (independent RR specialist) not Halfords tomorrow.
