![]() | Home > Technical (L322) > Brake Fluid/non starting |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3788 ![]() ![]() ![]() |
Cunifer |
p38arover Member Since: 16 Dec 2015 Location: Western Sydney Posts: 1544 ![]() ![]() |
I think he’s trying to peddle it ‘cos the pedal goes to the floor. Or does he need to pedal it like Fred Flintstone because it won’t start? I’m confused. 🤪 Ron B. VK2OTC
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1480 ![]() ![]() |
Failed vacuum pump?
Rosco Member Since: 20 Jan 2012 Location: Beyond the wall. Posts: 2587 ![]() ![]() ![]() |
p38arover, as indeed you craftily worked out I am trying to peddle it (see for sale section) nothing to do with the inactive brake PEDAL, my bad |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1784 ![]() ![]() |
New stuff needs to see brake pressure before it will crank
^^ lol Rosco Ron B. VK2OTC
Just to bump this thread, I gave mine an under-chassis clean earlier in off-road height and then turned on the ignition to drop it to access mode to then wash the car (letting the parking brake off in the process). The depressing lost the brake vacuum and I really had to stamp on the brake pedal very hard before it would allow me to start it later on.
