Home > Maintenance & Mods (L322) > Change mileage interval for service indicator? |
lschwarcz Member Since: 18 May 2019 Location: Hillsboro, OR, USA Posts: 273 |
I've long been in the habit of doing my car servicing every 5K miles regardless of what the car says. If the manufacture has special procedures (belts, plugs, etc.) above and beyond I do those at the recommend mileage/time.
6th Nov 2021 7:10pm |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3763 |
You can reset the service warning easily enough at any time with your iid, but I don’t think you can alter the frequency .
6th Nov 2021 8:42pm |
Thanks for the info!
6th Nov 2021 10:24pm |
p38arover Member Since: 16 Dec 2015 Location: Western Sydney Posts: 1523 |
What about for BMW based systems. i.e., 2002-2004/5?
But I think 25,000km is too long and want to change the value to 10,000km (max). FYI, I have a GAP IID, T4 (Testbook), and Faultmate MSV. I also have access to a local indie's Autologic. Ron B. VK2OTC 2003 L322 V8 Auto 2007 Yamaha XJR1300 Previous: 1983, 1986 RRC; 1995, 1996 P38A; 1995 Disco1; 1984 V8 County 110; Series IIA |
6th Jan 2023 1:47am |
Thanks Phoenix. I'm going to my indie's workshop on Tuesday so that info would be useful. I can grab his Autologic.
6th Jan 2023 7:18am |
Phoenix Member Since: 16 May 2022 Location: Gone Posts: 1631 |
It seems the service interval can only be changed on 06 onwards, at least with Autologic
7th Jan 2023 8:55pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16280 |
Larry, with the bonnet or hood open, the driver's door open, switch the ignition on without starting the car... Put both feet HARD down on the brake and the throttle peddles and wait! 10 seconds or so and you should get a message on the dash saying "resetting service milage" hold down and wait and then it will tell you its "reset service milage" and voila! oil reset completed sir... |
7th Jan 2023 11:28pm |
^^ Thanks Phoenix. Ron B. VK2OTC
8th Jan 2023 3:26am |
ergobyte Member Since: 03 Apr 2022 Location: bordeaux Posts: 124 |
Thanks, Craig
8th Jan 2023 11:54am |
No problem sir… It’s a weird phenomenon that’s worked on Range Rovers for many years… 👍 |
8th Jan 2023 12:04pm |
