Home > Maintenance & Mods (L322) > In need of some help |
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1350 |
1 - wheel balance, or buckle in wheel if they are low profile aftermarket alloys.
4th Jan 2023 10:15pm |
Range Rover L322 Member Since: 03 Sep 2019 Location: South West Posts: 329 |
Hi there + welcome! Hopefully the wheel balancing will solve it. If it doesn't then you might have a worn bush somewhere on the suspension or steering. Get underneath with a pry bar and see if something is less tight than it should be - any LR independent should be able to suss it out. Re the gears the same indy will be able to tell you if it's about right. I suggest posting your mileage, perhaps on a signature - some people may have some mileage related suggestions. Good luck and Happy New Year!... 2012 L322 4.4 TDV8 AB low mileage - a peach 1986 V8 Defender 90 County ex-Swiss Army - Red everything.... My preferred Independent: Roy Hardy. R & B AUTOS LTD, 20 Brook Road, Wimborne, Dorset, BH21 2BH 07500 866775 (Ex LR Chief Technician) |
4th Jan 2023 10:34pm |
Only_me Member Since: 01 Jan 2023 Location: Cardiff Posts: 8 |
Thanks for the info. The wheels are the standard 20" westminster alloys so im praying that correct wheel balancing will sort it today.
5th Jan 2023 5:14am |
Discotigger Member Since: 12 Feb 2013 Location: Cumbria Posts: 804 |
Hi there and welcome to the FF Club.
5th Jan 2023 6:10am |
Fox889 Member Since: 04 Jun 2019 Location: Bury St Edmunds. Suffolk Posts: 682 |
Welcome to the madhouse, good advice from the chaps on here.
5th Jan 2023 9:00am |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2469 |
I upshift manually most of the time to avoid unnecessary engine revs. IMO the auto programming doesn't make use of the engine's torque very well, especially when driven on light throttle. |
5th Jan 2023 9:56am |
How do they get access to the rear of the seat ? 2012 4.4 tdv8 westminster 128k miles |
5th Jan 2023 10:19am |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3187 |
Mine holds the revs too long going up hills but on the flat it's just about perfect. As I say to other first time buyers - get it to a LR indy specialist for a thorough inspection before you start throwing money and time at it. Although it's inevitable you will throw money and time at it as it's part of the ownership experience with an old L322 but you need to know what needs doing now and what can be left. 2012 TDV8 Vogue (L322) |
5th Jan 2023 10:27am |
V8 Bob Member Since: 15 Mar 2018 Location: Cumbria Posts: 357 |
Gearbox oil flush and change recommended at about 80,000 miles.
5th Jan 2023 12:23pm |
Stuart- Member Since: 16 Dec 2017 Location: UK and Hong Kong Posts: 301 |
If it's wheel balancing you should be able to drive through it, does it fade away at 70-80? If not, and the wheels themselves are OK, you may be into bushes or lower arms which they seem to need more often than you'd imagine.
5th Jan 2023 12:38pm |
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1205 |
My steering wheel had started to vibrate a bit at about 60mph but after changing the front suspension arms all is smooth again. |
5th Jan 2023 2:25pm |
S mode ? Where is that located as im new to all this and not seen anything about changing driving modes . 2012 4.4 tdv8 westminster 128k miles |
5th Jan 2023 2:55pm |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7788 |
The S on the rotary gear selector, as opposed to D.
5th Jan 2023 3:00pm |
SamThomas Member Since: 12 Nov 2021 Location: South East Posts: 293 |
Nobody seems to have mentioned the tyres themselves.
5th Jan 2023 6:39pm |
