![]() | Home > Technical (L322) > Smoke from.under the car |
Rambles Member Since: 16 Apr 2011 Location: UK Posts: 814 ![]() ![]() |
I get the same occasionally…but not often.
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7865 ![]() ![]() ![]() |
The exhaust for the FBH is down where the passenger side mudflap fastens on. In case your smoke came from a totally different area, and it will only run whilst the engine warms up and outside temp is low….
What does it smell of? |
Simons Member Since: 06 Dec 2021 Location: Daventry Posts: 9 ![]() ![]() |
Kind of diesel smell/exhaust?
Mine puffs out smoke from the OS wheel arch occasionally when it's cold outside and the FBH is working. The FBH is on the NS so no idea why but it smells of burning diesel. 2012 TDV8 Vogue (L322) |
It will fire up when the ambient is below 5deg. C and the coolant temperature is below (I think!) 75 deg. C. It will also fire up if the cabin heat demand cannot be fulfilled by the engine coolant temperature. The manual controls are additional to the above, not an override. The exhaust is angled under the vehicle, not to the outside, depending on the prevailing wind, it can appear from anywhere around the vehicle. |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8374 ![]() ![]() ![]() |
Or you could have a hole, crack etc in your engine exhaust pipe...... Pete
If that were the case, then there'd be running issues with exhaust smoke that colour if it was from the engine rather than the FBH |
Mine’s definitely FBH smoke. My thermostat is leaking so engine temps often dip below 75 deg during cold weather and the FBH helps out. 2012 TDV8 Vogue (L322) |
Yep, I missed the bit where the OP said it smoked... "should have gone to specsavers..." ![]() I now have permission from the boss to use Y.O.L.O. Enjoy life __________________________________________________ 2014 L405 Autobiography SDV8 4.4 Loire Blue Ebony interior 2011 L322 Vogue SE 4.4 TDV8 Baltic Blue. Sold 2012 L322 Autobiography 5.0 Supercharged Ipanema Sand Sold 2002 L322 Vogue 4.4 V8 Epson Green (Fatty Offroader) Sold -Click for Project Fatty off roader- |
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2272 ![]() ![]() ![]() |
It may have given up smoking as a new year resolution |
