Home > Technical (L322) > Smoke from.under the car
Simons
Hi all
Bit of a strange one
Once my Tdv8 3.6 has warmed up, if I spend any time stationery in traffic with engine on I start getting plumes of exhaust smoke/grey smoke from under the engine/ under the car?
Any ideas?
It smells too!!!
Post #652348 2nd Jan 2023 5:57pm
Rambles
2011 Range Rover Vogue SE TDV8 Stornoway Grey
I get the same occasionally…but not often.
I always put it down to the FBH
Post #652354 2nd Jan 2023 6:27pm
mjdronfield
The exhaust for the FBH is down where the passenger side mudflap fastens on. In case your smoke came from a totally different area, and it will only run whilst the engine warms up and outside temp is low….
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #652358 2nd Jan 2023 6:49pm
Phoenix
What does it smell of?
Post #652363 2nd Jan 2023 7:07pm
Simons
Kind of diesel smell/exhaust?
Does the FBH come on automatically? I don't have it switched on via the onboard computer - it's left on manual
Thanks
Post #652369 2nd Jan 2023 8:12pm
JayGee
Mine puffs out smoke from the OS wheel arch occasionally when it's cold outside and the FBH is working. The FBH is on the NS so no idea why but it smells of burning diesel. 2012 TDV8 Vogue (L322)
Post #652373 2nd Jan 2023 8:32pm
Phoenix
It will fire up when the ambient is below 5deg. C and the coolant temperature is below (I think!) 75 deg. C. It will also fire up if the cabin heat demand cannot be fulfilled by the engine coolant temperature. The manual controls are additional to the above, not an override. The exhaust is angled under the vehicle, not to the outside, depending on the prevailing wind, it can appear from anywhere around the vehicle.
Post #652374 2nd Jan 2023 8:34pm
Or you could have a hole, crack etc in your engine exhaust pipe...... Pete
Post #652378 2nd Jan 2023 8:57pm
Phoenix
If that were the case, then there'd be running issues with exhaust smoke that colour if it was from the engine rather than the FBH
Post #652380 2nd Jan 2023 9:15pm
JayGee
Mine’s definitely FBH smoke. My thermostat is leaking so engine temps often dip below 75 deg during cold weather and the FBH helps out. 2012 TDV8 Vogue (L322)
Post #652388 2nd Jan 2023 9:57pm
Yep, I missed the bit where the OP said it smoked... "should have gone to specsavers..." Shocked Pete
Post #652396 2nd Jan 2023 11:35pm
Sandyt
It may have given up smoking as a new year resolution Thumbs Up
Post #652465 3rd Jan 2023 7:01pm
