![]() | Home > Maintenance & Mods (L405) > drivers deployble side step not workimg |
comports Member Since: 20 Dec 2010 Location: Colchester Posts: 1749 ![]() ![]() ![]() |
Hi Gang,
Tinman Member Since: 22 Mar 2017 Location: kent Posts: 1200 ![]() ![]() ![]() |
Have you checked the plug from the loom to the step in front of the right rear wheel arch, not behind the arch liner?
Thanks Tinman,
I believe they are £545.36 less discount ( about £90 ) plus vat from Duckworths not sure if that is with postage 2017 SDV8 4.4 silicon silver AB
Have you tried unplugging and putting some power on the pins to see if it moves? 2017 SDV8 4.4 silicon silver AB
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3756 ![]() ![]() |
Or the module ? 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17 |
horse86 Member Since: 09 Dec 2014 Location: PA Posts: 863 ![]() ![]() ![]() |
Lots of aftermarket motors on eBay, alibaba etc.
Well…. Only related to my first post here because it relates to the stuck drivers side step but…..
