Home > Maintenance & Mods (L405) > drivers deployble side step not workimg
comports
United Kingdom 2016 Range Rover Autobiography SDV8 Mariana Black
Hi Gang,
Hope you're all ok - I'm having an issue with the driver's side deployable step and looking for your kind advice.
Passenger side is fine but for the last 2 weeks, the drivers side has stopped deploying. I dont hear any motor/servo noises at all (unlike the passenger side) so its most likely electrical (i think..)
Had a look around it but all looks to be connected and checked the handbook for fuses. given its a single fuse that supports both sides it can't be that.
I've reset the systsem with IID but nothing doing - the fault code comes back as the below so I'm assuming its a wiring fault..??
Is this likely to be a dealer/garage job or something I can look at myself?
As an aside - is there a way to lock the steps in their deployed state. It wouldn't worry me if they were always 'out' Ash
2022 SDV8 AB
2016 TDV8 VSE
2011 TDV8 VSE
2006 V8 Vogue
2002 2.5 Vogue
Post #651834 28th Dec 2022 6:59pm
Tinman
United Kingdom 2017 Range Rover Autobiography SDV8 Silicon Silver
Have you checked the plug from the loom to the step in front of the right rear wheel arch, not behind the arch liner?
Other than that it will be the motor which you can replace yourself but you may have trouble getting the step bolts undone.
Good luck. 2017 SDV8 4.4 silicon silver AB
2012 TDV8 4.4 Stornaway Grey AB
2011 TDV8 4.4 Buckingham Blue
2012 VW V6 3.0 Tougreg
Post #651837 28th Dec 2022 7:15pm
comports
Thanks Tinman,
I put it in off road height and had a quick look - seems like the wiring was intact and the plug wasn't loose (would be easier with ramp Rolling Eyes )
Could it be a broken wire in the loom or more likley to be the motor itself.? If motor, any clue as to the cost of a replacement?
Cheers Ash
2022 SDV8 AB
2016 TDV8 VSE
2011 TDV8 VSE
2006 V8 Vogue
2002 2.5 Vogue
Post #651838 28th Dec 2022 7:18pm
Tinman
I believe they are £545.36 less discount ( about £90 ) plus vat from Duckworths not sure if that is with postage 2017 SDV8 4.4 silicon silver AB
Post #651843 28th Dec 2022 7:55pm
Tinman
Have you tried unplugging and putting some power on the pins to see if it moves? 2017 SDV8 4.4 silicon silver AB
Post #651844 28th Dec 2022 7:57pm
cozzy
England 2015 Range Rover Vogue SE SDV8 Corris Grey
Stuck Step
Have you tried giving it a clean and lube all the pivot pins / mechanism ? My driver side got stuck ........gave it some spray white grease and all was good again !
Regards,
Cozzy.
Post #651849 28th Dec 2022 9:02pm
Vogue
Or the module ? 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17
Post #651852 28th Dec 2022 9:58pm
horse86
United States 2014 Range Rover Autobiography 5.0 SC V8 Causeway Grey
Lots of aftermarket motors on eBay, alibaba etc.
Anyone try replacing the motor on these? How difficult is it? I’ll be needing to do the same 2014 FF Autobiography 5.0 SC
2008 FFRR (sold)
2008 BMW M5
Post #652133 31st Dec 2022 12:54am
comports
Well…. Only related to my first post here because it relates to the stuck drivers side step but…..
Does anyone know how to replace the front bracket ? Because mi e had stuck out slightly but not fully deployed, I went very slowly over a kurb stone and it broke the front bracket 😭😭😡
I’ll speak to Duckworths tomorrow but I think the bracket alone is about £200.
Anyone know if I’ll just need to unbolt the old from beneath and bolt the new one in place or is it a strip out in Teri or to do it from above ?
Thanks all Ash
2022 SDV8 AB
2016 TDV8 VSE
2011 TDV8 VSE
2006 V8 Vogue
2002 2.5 Vogue
Post #655091 29th Jan 2023 8:40pm
