Home > Technical (L322) > Information button on indicator stalk
Page 2 of 3 <123>
GraemeS
Australia
My trip computer menu only provides selection of A, B or auto trip recording.
Post #651644 26th Dec 2022 12:02am
filthyliam
So I disconnected the battery and left it 24 hrs, reconnected and the display had changed to the date and total mileage on the dash. The silver button on the stock still didn’t change anything when either held in or pressed. I then used the steering wheel buttons to scroll to trip computer which allows trip a to be selected but then I can’t change back to
Date and total mileage or range, mpg etc. I think this has to be a stalk issue surely ?
Post #652057 30th Dec 2022 3:02pm
Phoenix
Or a wiring issue...
Do you have any DTC's in the instrument pack? specifically B1A82-23
The button is connected to the IPK by a Yellow/Red wire, pin 1 on the switch, pin 6 in C0230 on the IPK. There is no information on what type of signal it is, If I were to hazard a guess, it'd be pulling down to ground.
Post #652058 30th Dec 2022 3:28pm
filthyliam
Ok thanks bit advanced for me. But I have a thought that when it runs low on fuel and tells me how many miles left until empty I think it may go onto “ range” at that point. If I then put fuel in it it could remain on range rather than go back to “ trip A” worth a try anyway before a trip to the garage
Post #652209 1st Jan 2023 2:09am
Phoenix
If all you want to do is have the range displayed, use the setup menu on the infotainment screen to deselect everything else.
Post #652220 1st Jan 2023 11:12am
filthyliam
Ok thanks what’s it under on infotainment ? Can’t seem to see this on the menu ?
Post #652222 1st Jan 2023 11:17am
Phoenix
Have a look at p95-96 in the owners handbook, if you don't have one you can find it online
Post #652225 1st Jan 2023 11:37am
filthyliam
95-96 are climate control in my book. I have been though it today and can’t seem to see a section that says you can alter what you see on the dash from the infotainment to change it to range.
Post #652316 2nd Jan 2023 2:56pm
Phoenix
https://www.fullfatrr.com/gallery/albums/u...%20OBC.pdf
Just for morbid curiosity - and to help narrow things down a bit, what year is your L322?
Post #652318 2nd Jan 2023 3:03pm
filthyliam
2009 one of the first with the full digital dash etc
Post #652323 2nd Jan 2023 4:04pm
filthyliam
Yep I don’t have any displays in the infotainment that look like this sorry
Post #652442 3rd Jan 2023 2:45pm
Weegie
Just to add to this, my 2008 3.6 has the facility. Appears on the touch screen for selection of information wanted. John
GAP iiD BT-Sold
Post #652443 3rd Jan 2023 2:49pm
filthyliam
Ok thanks that’s good to know, do you know what it shows as on the menu on the infotainment or what I need to select ?
Post #652457 3rd Jan 2023 6:17pm
a long press on the stalk end button will make this menu pop up... ... - .- -.
Post #652459 3rd Jan 2023 6:28pm
Phoenix
Not if the button circuit has a fault though...
Post #652461 3rd Jan 2023 7:25pm
Page 2 of 3 <123>
