Home > Maintenance & Mods (L322) > New purchase rear creaking/squeaking
Nyorks2022
My new to me 4.4tdv8 has a very creaky/squeaky rear end any pointers on what to clean/grease or change it’s very loud outside of the car and quite embarrassing ha just had a new mot from a local garage and nothing was picked up on suspension but has been sat for sometime …
Post #651967 29th Dec 2022 6:23pm
aljo
United Kingdom 2019 Range Rover Vogue SE 2.0 PHEV Santorini Black
More likely or not your anti Roll bar bushes ?
Spray some WD40 on them to confirm 👍 Last night I lay in bed looking up at the stars in the sky and I thought to myself, where,s the f**king ceiling!!
Post #651973 29th Dec 2022 7:06pm
JayGee
Mine did his last summer - it was like driving around on a squeaky mattress Embarassed I think it went away when I had a failed upper outer suspension joint replaced for the MOT but it may also just have been the damper colder weather that set in at the same time. In the summer I got under it and sprayed every bit of runner with a silicone spray lubricant but it didn't do anything. 2012 TDV8 Vogue (L322)
Post #651982 29th Dec 2022 8:05pm
p38arover
Australia
Could be the rear bushes. I replaced mine a few years back, one was breaking up. The new bushes still squeak.
 Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #652009 30th Dec 2022 3:15am
garyRR
This is interesting. Under hard acceleration (and only this) I get a squeak from a rear corner of the car. I shall spray some silicone lubricant to confirm/deny. 2015 Range Rover Autobiography 4.4 SDV8
Post #652012 30th Dec 2022 4:24am
Nyorks2022
Thanks for this will investigate got a list of niggles to get through but bought her cheap enough to go through them this is a horrid creaking can’t hear it inside when the windows are up lol
So far deployable steps one stuck out one stick in this horrific creak and the tailgate is rusty lol
Post #652047 30th Dec 2022 1:26pm
Nyorks2022
I have a front knocking on the suspension also so the worst creaking/squeaking on drivers side rear and the front also
For a full suspension overhaul what’s best to source/buy ? All arms and ?
Post #652258 1st Jan 2023 5:22pm
depends on budget, the LR stuff is made by either Delphi or Lemforder depending on who the supplier was at the time, so aftermarket can be ok so long as you are selective.
knocking can be one of a couple of things, lower/upper arm ball joint on the front hub or it can simply be the ARB drop links. There is nothing that can't be fixed with a hammer😜😜
Post #652266 1st Jan 2023 5:53pm
Nyorks2022
Think this time round till I get some heavy duty ramps and stands etc for her I’m going to drop her off at a local specialist near Scarborough to get the suspension overhauled and start working through the other stuff in time
Post #652342 2nd Jan 2023 5:31pm
