Home > Maintenance & Mods (L322) > New purchase rear creaking/squeaking |
aljo Member Since: 04 Jul 2018 Location: west sussex Posts: 202 |
More likely or not your anti Roll bar bushes ?
29th Dec 2022 7:06pm |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3231 |
Mine did his last summer - it was like driving around on a squeaky mattress I think it went away when I had a failed upper outer suspension joint replaced for the MOT but it may also just have been the damper colder weather that set in at the same time. In the summer I got under it and sprayed every bit of runner with a silicone spray lubricant but it didn't do anything. 2012 TDV8 Vogue (L322) |
29th Dec 2022 8:05pm |
p38arover Member Since: 16 Dec 2015 Location: Western Sydney Posts: 1533 |
Could be the rear bushes. I replaced mine a few years back, one was breaking up. The new bushes still squeak.
30th Dec 2022 3:15am |
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1468 |
This is interesting. Under hard acceleration (and only this) I get a squeak from a rear corner of the car. I shall spray some silicone lubricant to confirm/deny. 2015 Range Rover Autobiography 4.4 SDV8 |
30th Dec 2022 4:24am |
Nyorks2022 Member Since: 04 Sep 2022 Location: North yorkshire Posts: 33 |
Thanks for this will investigate got a list of niggles to get through but bought her cheap enough to go through them this is a horrid creaking can’t hear it inside when the windows are up lol
30th Dec 2022 1:26pm |
I have a front knocking on the suspension also so the worst creaking/squeaking on drivers side rear and the front also
1st Jan 2023 5:22pm |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8523 |
depends on budget, the LR stuff is made by either Delphi or Lemforder depending on who the supplier was at the time, so aftermarket can be ok so long as you are selective.
1st Jan 2023 5:53pm |
Think this time round till I get some heavy duty ramps and stands etc for her I’m going to drop her off at a local specialist near Scarborough to get the suspension overhauled and start working through the other stuff in time |
2nd Jan 2023 5:31pm |
