![]() | Home > Technical (L322) > Differences "Frame" Range Rover Lm/Disco3&5 |
mattstevenson2005 Member Since: 01 Jan 2011 Location: Manchester, UK Posts: 737 ![]() ![]() ![]() |
When Ford owned Land Rover they designed the T5 platform, this is what the Disco 3/4 and RR Sport is built on, when they designed the platform it was intended to be used for all replacement models e.g. defender etc... When BMW owned Land Rover it cost them almost 1 billion pounds to design the L322 Range Rover so yes it was very expensive!
The monocoque chassis (unibody) is much stronger than any separate body/chassis design, the new Range Rover Evoque and soon to be released 'NEW' full size Range Rover both use Jaguars new 'spaceage' monocoque chassis platform as it provides increased strength and lower weight than any other chassis design. As i explained before when Ford built the Disco 3/4 and Range Rover Sport they wanted to use there new T5 chassis platform for all future Land Rover designs which is why it is designed as a separate body and chassis design so that the same chassis can have multiple different bodies. When Land Rover re-design the disco and RR Sport they will dropping the T5 platform as it is far too heavy in a time when they are trying to loose vehicle weight to increase economy levels, and all new models will be based on the new Jaguar platform. Hope this helps! Matt |
Defenderfan Member Since: 15 May 2011 Location: Germany Posts: 6 ![]() |
Hello,
No one else anything about the Design?
S1NGH Member Since: 08 Apr 2009 Location: All over Posts: 40 ![]() ![]() |
Click on the link below and take a look at the photos of an RRS with its body lifted, might have to register to view pics (rrs chassis virtually the same as D3, only difference is length). You can see that its a monocoque body attached to a ladder frame. Probably the strongest Land Rover chassis.
Hi,
The LM platform is completely different - a pure monocoque, without the ladder chassis that the T5 platform incorporates. The T5 is like a double chassis.
Hi,
What are you planning that needs the max strength of a chassis??
Hello,
GKP Member Since: 01 Aug 2009 Location: Hants Posts: 75 ![]() ![]() ![]() |
One of the reasons for 'going backwards' was to make it easier to manufacture two different vehicles but sharing as many of the components as possible, thus keeping costs down. Not sure you should be reading this bit. |
