![]() | Home > Maintenance & Mods (L322) > Persistent injector driver circuit performance bank B |
I saw this once, it was a corroded fuseholder - sorry but I can't remember which one, it was about six years ago. I'd start by checking all the +ve & -ve connections to the control module. Testing resistance won't show volt-drop, you need to be measuring with a volt meter at either end of each wire with the circuit under load. Resistance checks on an isolated circuit will only show the very worst of problems.
peternicholls Member Since: 12 Mar 2022 Location: Stoke-on-Trent Posts: 36 ![]() ![]() ![]() |
Hi. Cheers. There are no fuses for injectors, come straight off a mosfet on the Ecu from what I can gather. Power in to Ecu, wouldn’t it affect both sides not just bank b? |
I know there are no fuses for the injectors directly, I can't remember the exact details but I think there is more than one fuse for the 'power' (as opposed to sensor supply) input to the ECM. On the 3.6TDV8 there is one 25A fuse with a splice in the harness that splits the supply between three inputs. either way, IMO you need to check all pins that supply 12V or ground for volt drop between the source and the ECM connector, I'd also be checking pin grip on those terminals and the output terminals too. Too often I've seen tech's stumped by pin grip, particularly on control modules or sensors etc. as it's near-impossible to check without a breakout box or test pins. |
Oh thanks. That’s interesting. I’ve plenty of back probes, will need to have a study of the pins and wiring diagram. You don’t happen to have a pin guide of the Ecu side? |
Pin guide? do you mean wiring diagram? If so:-
My diagrams are labelled 07, those 08. But seem similar where it matters after close inspection. |
Now that’s interesting - no I didn’t. All tests I did at 240v as that’s as low as mine goes. I’ll try this though. (Thursday - I’m outside so need dry days!)
Not connected injectors grounding to body only. So back probe the ecm at the ground connector and the other probe to the bodywork ground? I did this without injectors connected and there was 0.00 resistance. Did not do with injectors connected nor at injector end. But connector to connector the loom showed 0.00 resistance. |
Now I’ve just compared pins and interesting…
Personally I'd go straight to a good ground point on the engine, as that's where it'd be shorting (or resistively connecting) to with the other probe on each injector connection at the ECM plug in turn - that way you're not 'losing' any lack of resistance through multiple connections. As far as I'm aware, there was no change in pin-out during the life of the 3.6TDV8, the VIN & MY annotation simply shows it to be applicable to the selected vehicle. The screenshot below indicates the part number for the ECM supercedes to the later one so the pinout must be the same. ![]() |
To be clear, we’re not talking about the injectors shorting to ground? As I’ve tested all those throughly. |
And I need to go back and test all 8 plugs to ECM to see what’s going on - may have found the smoking gun! |
I was asking if you'd tested the harness to ground, with the harness connected at the injector end - to rule out any connector issues. I assume you've also tested the injector terminals for an internal short to the body. the pin-to-pin resistance and capacitance would show OK but you could still have one side shorting or resistively connecting to ground. |
As I read it, the pin-out should be
Hi, rain stopped play today. Harness to ground - got you! No. That’s a very interesting test. You assume correct on the injector terminals / short. That’s how I came to replace cylinder 6’s injector. So on the diagram I’m seeing cylinders are 1-8 as per the actual engine, injection numbers seem to be firing order. I have an anomaly with the wires to cylinder 7 [6 on your listing] - so there may be a break or short. I’m going to start from basics again Thursday and metehodically test everything once again. |
