Home > Technical (L405) > Help - way to open lower tailgate manually?
MrWold
England 2014 Range Rover Autobiography SDV8 Barolo Black
So main battery out for a full Ctek charge and check then I closed the lower tailgate Fortunately put an old sock in the catch for the upper so that can't close. Is there a way to open the lower one manually otherwise it's a long reach down to drop the battery back in. Had a feel around but can't find anything. Chris
2014 FFRR 4.4 SDV8 Autobiography Barolo Black
2012 RRS SDV6 HSE Baltic Blue
and before I saw the light:
2011 Suzuki Grand Vitara SZ5
1998 Ford Mondeo V6 Ghia X
1990 Citroen BX GTi
1973 Triumph GT6
Post #651717 27th Dec 2022 12:40pm
SamThomas
United Kingdom 2003 Range Rover Vogue Td6 Baltic Blue
Don't know if its the same as an L322 but they have a couple of manual catches either side (top corners), but they are fiddly.
Post #651726 27th Dec 2022 3:12pm
fisha
Not just use a set of jump leads between the battery and car leads for long enough to press the button ? V8 or else ...
Post #651727 27th Dec 2022 3:13pm
Tinman
United Kingdom 2017 Range Rover Autobiography SDV8 Silicon Silver
Jump points under the bonnet with jump lead I know because I did the same thing Big Cry
Only I closed both tail-gates 2017 SDV8 4.4 silicon silver AB
2012 TDV8 4.4 Stornaway Grey AB
2011 TDV8 4.4 Buckingham Blue
2012 VW V6 3.0 Tougreg
Post #651730 27th Dec 2022 4:15pm
MrWold
Thanks good suggestions but managed over the lower tailgate but it's long and heavy drop, for me anyway. Fortunately none of the little wires got caught up. Chris
1990 Citroen BX GTi
1973 Triumph GT6
Post #651732 27th Dec 2022 4:26pm
