Home > Technical (L322) > Range Rover 2010 V8 5.0 Suspension Codes C1A07-62 & C113
bearhouse
United Kingdom 2010 Range Rover Autobiography 5.0 V8 Santorini Black
Hi All,
My Range Rover 2010 V8 5.0 has developed a fault. While driving, the suspension fault warning came up saying to drive at 30mph max. Then a message came up to say it would raise once the system had cooled. Now, the front goes down evenly over night but raises once started and occasionally the warning comes up while driving.
I took it to a local garage who are not Range Rover experts. They put their diagnostic machine on and read all the fault codes of which there were many. The printed off the codes then cleared them all. The plan is to go back once the fault re occurs and read the code then stored. But the two codes that look relevant from the list of codes that were stored are;
C1A07-62 - Cross Articulation
C1130-7a - Air Spring Air Supply
Does anyone know what these codes mean and if they may indicate my problem?
Many thanks in advance.
Post #651429 22nd Dec 2022 8:42am
have a look at the brass filter on the air compressor....take it off and see if its blocked ..
if yes then replace or drill a small hole through it.. ... - .- -.
Post #651433 22nd Dec 2022 10:12am
bearhouse
Many thanks for your suggestion. Can you advise where to find the brass bush / breather?
Post #651434 22nd Dec 2022 10:25am
on the air compressor in the boot well.. ... - .- -.
Post #651435 22nd Dec 2022 10:27am
bearhouse
Many thanks for that. Can I ask what it does and why it might cure my problem.
Post #651442 22nd Dec 2022 12:55pm
if the brass filter is blocked then the air cant get to where it needs to go....this might be your problem and its a good starting point.. ... - .- -.
Post #651445 22nd Dec 2022 1:11pm
