![]() | Home > Technical (L322) > Range Rover 2010 V8 5.0 Suspension Codes C1A07-62 & C113 |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35649 ![]() ![]() |
have a look at the brass filter on the air compressor....take it off and see if its blocked ..
bearhouse Member Since: 18 Jul 2020 Location: Hemel Hempstead Posts: 10 ![]() ![]() ![]() |
Many thanks for your suggestion. Can you advise where to find the brass bush / breather? |
on the air compressor in the boot well.. ... - .- -.
Many thanks for that. Can I ask what it does and why it might cure my problem. |
if the brass filter is blocked then the air cant get to where it needs to go....this might be your problem and its a good starting point.. ... - .- -.
