Home > Technical (L322) > Rear airbags, front dropped. |
Ramblin Man Member Since: 05 Apr 2022 Location: Southsea Posts: 281 |
Did you go through the height calibration procedure ? TDV8 4.4 2012 |
12th Dec 2022 1:56am |
J2B Member Since: 03 Jul 2020 Location: kent Posts: 52 |
No I haven't as of yet, I'll put the new sensor on then go through it, thanks. |
12th Dec 2022 3:43pm |
I’d suggest trying to calibrate first. I learned that all sorts of errors occur if the sensors are unevenly adjusted. I recently had an suspension failure whilst driving and went through an arduous replacement of the sensor only to find that it was most likely a calibration issue. If the sensors are out side the ECU calibration range or if there is too much difference between sensors on opposite sides of the car the system throws all sorts of warnings. Mine dropped onto the bump stops.
12th Dec 2022 9:29pm |
Thanks very much for your pointers very much appreciated, finding time to do it now |
12th Dec 2022 11:33pm |
Managed to get the front end up, no thanks to the iid tool wouldn't connect to my phone again.
19th Dec 2022 8:10pm |
Phoenix Member Since: 16 May 2022 Location: Gone Posts: 1631 |
What is being shown on the 4x4i screen? are the heights plausible?
19th Dec 2022 8:13pm |
thanks for your reply , screens just got range rover and a flashing button at the moment another issue so cant access that first thing i would have looked to be fair just to see, need to get the iid tool to connect. |
19th Dec 2022 8:46pm |
OK, have you looked at the height sensors all round to make sure they're all in the correct position and not gone 'over centre' during the repair operations? Also that all the plugs are fully latched in place on them? I appreciate it might be difficult with it dragging it's @rrse on the floor like a dog with worms!
19th Dec 2022 8:53pm |
im thinking with the rear passenger side sitting arse down and front drivers up in the air i think its gone over, will get on it over the next few days |
21st Dec 2022 11:07pm |
I did get this sorted in the end early March this year, 2 x new complete front legs, as one burst,was the original legs, another new front level sensor oem this time and a bit of fettling thanks to Martin at Dartford Transmissions. |
29th Dec 2023 10:25pm |
